Will 04 coupe radio/climate control assembly work in an 03?
Old Aug 10, 2011 | 10:45 PM
infin8's Avatar
Radio went nuts the other day and won't turn off. For the time being I've pulled the radio fuse so that it won't drain my battery. After I pulled the fuse, my climate control is stuck on the last setting I had it at.
Been reading through the existing threads on this common problem with the radio failing and the AC/climate control going haywire.
I have the opportunity to obtain the radio and other parts from a wrecked 04 coupe, wondering if swapping in these parts will work?
Old Aug 11, 2011 | 09:45 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
It should work fine, so long as they're both bose or both non-bose headunits. Just make sure you get the trim plate as well, as the circuit boards and radios don't always line up between early 03s and 04s on the trim.
Old Aug 14, 2011 | 11:30 PM
infin8's Avatar
Thanks! Turns out I wasn't able to get the parts from the coupe, but the parts from an 03 sedan might be available. Do you know if the sedan pieces will work also?
I'm now starting to experience intermittent starting issues, could this be related to the problem with the circuit board in the radio as well? Or is this a totally different problem now?
Old Aug 14, 2011 | 11:49 PM
Yeah, sedan and coupe radios (but not bose amps) are all interchangeable same year for year, except for 07, when the sedan got the body update and the coupe didn't.
arora_g35
Apr 16, 2026 02:52 PM
rezendvous420
May 31, 2020 01:26 PM
yassy
Aug 3, 2015 12:24 AM
teamghost
Jul 28, 2015 04:52 PM
papo020
Jul 17, 2015 10:30 PM
