Double Din help.
Old Sep 1, 2011 | 05:49 PM
nmelone21's Avatar
Double Din help.
installation of my DDX418 is complete, but now i'm in need of some guidance on what to do with the trim ring. the piece that came with the Kenwood will not kit with the JDM dash kit.
any suggestions on what i could do would be appreciated.
Old Sep 1, 2011 | 10:27 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
From the shopping list:
Scosche DDTRB universal trim ring. Scosche DDTRB universal trim ring.
Old Sep 2, 2011 | 06:53 AM
StrongG35x's Avatar
Not to threadjack, but Wrathernaught- does that trim ring pull the deck out beyond the kit a little? So it goes (Kit/Trim/Deck) and the deck then sticks out a bit OR does it go (Deck/Trim/Kit) so it sits back a little? On my install I opted not for the trim ring, but they fabricated a trim-piece to slide over the back of the deck and fill the gap, so the deck is flush with the kit...just curious...
Old Sep 2, 2011 | 09:18 AM
KnowScott's Avatar
You can trim the trim ring however you want, its very thin. I have mind behind the JDM kit.
Old Sep 2, 2011 | 10:47 AM
The ring is very thin, like, 8 sheets of paper thick, and should not affect the position of the radio in any way. The radio screws in via the factory bracket holes (or new holes of your own making) - that determines how much the deck sticks out or recesses. A thick trim plate (like the Metra 99-9999) could be thick enough to necessitate moving the radio back and drilling new holes, depending on the radio.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
Oregon13
Mar 1, 2016 12:06 AM
BfloG35
Oct 16, 2015 05:22 PM
