Amp and Speaker Replacement - Please verify
Which is the better brand here
http://www.sonicelectronix.com/item_...ch-P500-2.html
http://www.sonicelectronix.com/item_...11ZX450.2.html
The thing I like about JL is that they SAY they push out the full 150x2 from 1.5-4 ohms AND from 11-14.5V. This is important because some other brands can say 150x2 rated at 14.5V, but our cars are rarely running at 14.5V because of every other electronic part that is taking up some energy as well. My car runs at a constant 12V pretty much..
I recommend it completely.
Hit up www.sounddeadenershowdown.com and get at the very least some CLD tiles. You only need about 10 tiles to do both doors. Adding the closed-cell foam and mass-loaded vinyl barrier will help further.
I recommend doing the trunk as well, it's just as important as the doors.
I don't have photos, but you just have to put it on the inside of the outer door skin the inner door skin, and the metal door panel that bolts in. exact placement isn't critical, but cutting them will be required to get in some places. I used some sheet metal shears to do the job.
a few remaining questions:
1) explain to me the pitfalls of leaving my infinity 6030cs tweeter and crossover, and simply installing the ID CX-62 midbass driver and connecting it to the existing crossover.
2) i assume since its 2ohm, my existing stock speaker wiring can handle the amp and ID speaker. right or wrong?
nettcar
Aug 25, 2024 11:59 PM
Thunderaan
Jul 22, 2015 07:40 PM
