FS[NorCal]: Car PC + DD Kit
Old Dec 17, 2011 | 04:19 PM
magic5g's Avatar
What city are you in? And what cables are missing exactly when you say missing cables? Power? Rca? vga? etc. what cables would I need to have this up and running in my car.
Old Dec 20, 2011 | 11:21 PM
tlu's Avatar
tlu
Is the sedan and coupe DD KIT the same? i have a 06 coupe and im wondering if this will fit. if it does i can come pick it up
Old Dec 21, 2011 | 12:17 AM
RussianMan's Avatar
dont think so but not sure might be good to ask someone else
Old Feb 23, 2012 | 10:03 PM
RussianMan's Avatar
back in country sorry for all no reply messages, need it gone
Old Feb 25, 2012 | 12:25 AM
kyle5486's Avatar
What kind of screen is it?
Old Feb 25, 2012 | 02:34 PM
stevenpk's Avatar
+1 on what cables are needed. I wouldnt want to buy this and then have to figure out what else i needed to make it run.
Old Feb 27, 2012 | 04:08 PM
cbrock's Avatar
very interested if you can tell us what sort of cabling needs would be required.
Old Feb 28, 2012 | 08:51 PM
RussianMan's Avatar
http://umumble.com/blogs/DIY/210/
hope that helps some, getting it running is pretty easy the most challenge will be powering amp and speakers through pc. radio shack has some rca cables that go from 1 (pc) side and split to 2 (amp)
Old Feb 28, 2012 | 09:03 PM
RussianMan's Avatar
In order to connect the car amp to your pc do the following:
1. Get a 3.5mm to RCA cable so that you connect the pc sound
card output to the amp input.
2. If your amp has a "Level" control, turn it to the highest voltage
(since i dont know what power supply you are using, this
reduces the chances that your amp will overload)
3. Connect suitable car speakers to the amp.
4. Connect a 12V power supply (Not the same one your
computer is using!) to the car amp, running the +12V to the
power and remote terminals.
Old Feb 29, 2012 | 03:08 PM
RussianMan's Avatar
Pc SOLD!!
Jdm dd kit still available
Jusseth
Sep 13, 2020 12:25 PM
mjfenix
Aug 17, 2017 05:49 AM
slider_ua
Jul 29, 2015 04:17 PM
Chattzx
Jul 17, 2015 11:23 AM
beevanhuynh
Jul 14, 2015 09:06 AM
