GROM USB Bluetooth Aux install
Old Nov 23, 2014 | 11:53 PM
Creedence85's Avatar
G35 Sport Sedan 6MT
Vanessarino, after you confirm that the GROM is installed correctly and is getting power, try turning off the radio, unplugging the GROM, plug it back in, and power up the radio. Unplugging and plugging the GROM resets it. If this doesn't work then contact GROM tech support http://www.gromaudio.com/support.html as they respond quickly with good procedures. I've had a couple issues which they helped me resolve.
Old Nov 24, 2014 | 12:20 AM
Vanessarino's Avatar
Originally Posted by .cakestar
do you have the bluetooth attachment? it comes as an added accessory.
first i would checm that the unit is getting power. take a usb stick that has an led and plug it in. confirm that the light turns on or use an iphone usb cable and comfirm its charging your phone. if it is not then the unit is not powering up and you might have tapped the wrong wire for power
Yes i bought the bluetooth add on.
Which is the right wire to tap? I did it on the yellow wire which was part of the cables diagonally attached to the grom cables.
Old Nov 24, 2014 | 12:38 AM
.cakestar's Avatar
i dont remember the color to tap for power. can you confirm you are getting power to the unit? does the usb stick led light up? or usb cable?
Old Nov 24, 2014 | 01:15 AM
G35 Sport Sedan 6MT
I'm pretty sure it's the yellow wire. I just checked the FSM and it notes the yellow wire.
Old Nov 24, 2014 | 09:06 AM
I don't have a usb stick but I tried plugging my phone through the iphone cable and it doesn't charge.
Old Nov 24, 2014 | 11:06 AM
joedaddy1's Avatar
if your iphone isn't charging.. your grom probably isnt getting power..
take the plastic cover off the grom unit. if your car/audio is on, there should be a red LED light that stays on. if it's not on, it's not getting power.
Old Nov 24, 2014 | 07:32 PM
G35 Sport Sedan 6MT
I'm going to guess there's no power, so you may have a bad connection or the wrong wire. Redo your wire tap to make sure you have a good connection and if there's any doubt check it with a multimeter or circuit tester.
Old Nov 24, 2014 | 09:58 PM
.cakestar's Avatar
double check you are tapping the correct power wire for your year model. idk if it varied from 04 to the 05-07 editions
Old Nov 26, 2014 | 02:01 PM
Drifter2090's Avatar
I am planning on buying one of these:
http://www.gromaudio.com/store/andro...interface.html
http://www.gromaudio.com/store/bt3_a...emulation.html
I just had some questions, Do you need the AAlinq app to play music from your android phone through USB or bluetooth? is there a big difference in audio quality between USB and Bluetooth? Do you need the app for steering wheel controls?
Lastly do the steering wheel controls work with USB flash drive plugged in?
Thanks
Old Nov 26, 2014 | 09:24 PM
joedaddy1's Avatar
GROM works pretty well with the steering wheel controls.
the difference in quality of BT and wired is measurable.
BT is like 1000 times more convenient, but it feels like i am listening to 96kbps/128kbps MP3's... which isn't bad.
Wired setup feels like 192kbps+.. the bass and voices sound more clear
Old Nov 27, 2014 | 11:31 AM
Thanks I went and bought the Grom USB3
Old Nov 27, 2014 | 03:46 PM
G35 Sport Sedan 6MT
Drifter2090, the USB3 should be a good choice as it has all the options. When I first installed my USB2 there was a measurable audio quality reduction with BT which became even more apparent after I upgraded the the amps and speakers. I wouldn't worry about it if you prefer convenience over quality, as I still find I use the BT from time to time, but if you're an audiophile you'll notice it.
I find the BT is like low bitrate encoding, and there are key components of the sound missing or modified. The low frequencies are reduced, vocals and upper mid range are reduced in clarity, and there is an echo effect with certain frequencies. The USB flash drive can be equal or even better than CD with a high bitrate encoding. The aux input is as good as the phone, mp3 player or whatever source you've connected can reproduce, not quite as good as the USB but pretty good. AAlinq is good but there are definitely missing components in the sound so not sure if that's due to the app. I haven't heard the Android streaming on a USB3 unit or iPhone on my USB2.
Old Nov 27, 2014 | 07:28 PM
Thanks for all the help man! Yeah I care a lot about audio quality I didn't even order the additional Bluetooth piece. Also update your USB2 firmware here:
http://www.gromaudio.com/software-usb2.html
"USB Audio streaming with control supported for USB2P" it will let you use steering wheel controls while USB streaming w/o the AALINQ app.
Old Nov 27, 2014 | 09:24 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
The actual A2DP bluetooth streaming audio protocol *shouldn't* be a limiting factor, it's more about what sort of compression over the a2dp stream your device is using. http://soundexpert.org/news/-/blogs/...o-quality-a2dp
Old Nov 28, 2014 | 06:38 PM
  #30
G35 Sport Sedan 6MT
"USB audio streaming with control supported for USB2P" it will let you use steering wheel controls while USB streaming w/o the AALINQ app.
I have a USB2 not a USB2P, as I bought it over 3 years ago now. It can' t do USB audio stream, it can only do it with AAlinq. I'll be curious to hear your impressions of the USB audio stream once you get it setup. I probably won't buy a new unit for this car anytime soon, but would consider it for another car.
