getting power wire through firewall
Old Dec 23, 2004 | 02:42 AM
chuckd05's Avatar
I am debating on whether or not i want to install my system myself... i took a glance under the hood and had a hard time finding a spot where i could get the power wire through.... Is the install hard/easy? Ive done several installs on my passed cars but this one seems it may be tough.... if anyone has a DIY with working pics , i searched but all the links are not workin corectly....
Old Dec 23, 2004 | 10:23 AM
COUPEDIT03's Avatar
I watched my installer run the power wire from the battery to behind the motor and across to the other side of the car- I guess there was some sort of opening there. Hope that helps.
Old Dec 23, 2004 | 10:38 AM
afr0puff's Avatar
Supa Dupa Moderator
It's real easy. Just time consuming. Behind the battery is a gromit leading into the cabin on the extreme passenger side. Take apart the glove box as seen in the numerous DIY. You will see the other end of the gromit. Poke a hole and feed your cable through.
Old Dec 23, 2004 | 01:47 PM
Meatshackle's Avatar
Deep Sea Moderator
there is a write up in the DIY section.
Old Dec 24, 2004 | 01:53 AM
chuckd05's Avatar
link? i seen a few with all the pics not workin, pics would help tremendously.... thanks!
Old Dec 24, 2004 | 09:59 AM
KPierson's Avatar
I drilled a hole right under the ECU. It ended up right in the battery compartment, and I didn't have to take the glove box out. If I remember right the grommet is right above the ECU which can lead to water dripping on it if you don't seal the hole. Drilling a hole under the ECU eliminates that from happening.
ara777
Oct 25, 2017 01:45 PM
Vqalexisz
Oct 14, 2015 12:48 AM
Danielek
Oct 7, 2015 09:59 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
zcherub
Sep 10, 2015 12:03 PM
