Easiest Way to Access Plug for Center Console Power Outlet? 05 Coupe 5AT
Old Dec 8, 2011 | 06:20 PM
JadeRaven's Avatar
I checked the fuses, but the power outlet in the console under the armrest is still non-functional. I'm guessing a plug somewhere along the line is disconnected.
Is there any easy way to pull off the armrest/box and check to see if it's hooked up?
Thanks!!
Old Dec 8, 2011 | 07:09 PM
JadeRaven's Avatar
OOoo I think I found the answer to my problem already. . .
Open the box, pop out panel in the back and remove two front screws, and then the console simply pulls out of its clips.
I'll have to try tomorrow.
I appreciate any other tips though
Old Mar 17, 2012 | 01:52 AM
kozy's Avatar
Did that work? Looks simple enough.
Old Mar 17, 2012 | 06:13 PM
JadeRaven's Avatar
Yep that's all it was. My power outlet never worked, turns out all these years the harness was unplugged.
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
R350k5
Oct 1, 2015 08:41 PM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
