Alpine System Suggestions
Old Dec 23, 2011 | 03:21 AM
Kissoon13's Avatar
I was going to order these today for my 04' coupe but i wanted some suggestions from you guys first...I'm going with these 3 items.
1. Zenclosure Box
2. Alpine Subwoofer SWX-1043D
Specs:
Power Handling:
Power Range: 500 - 1000 Watts
RMS Power Handling: 1000 Watts
Peak Power Handling: 3000 Watts
Frequency Response: 26Hz - 200Hz
3. Alpine Amp MRX-M100
Specs:
Max Power: 1900W
RMS Power Ratings:
Per channel into 4 Ohms: 600W x 1 (@14.4V Ƈ% THD+N, 20Hz - 200Hz)
Per channel into 2 Ohms: 1000W x 1 (@14.4V Ƈ% THD+N, 20Hz - 200Hz)
What do you think about this combo?
...Oh yeah and I've already changed my inside speakers to all Alpine Type-R's.
Old Dec 23, 2011 | 10:53 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Zenclosure:
Mounting depth - approx. 7" using a sub with a 6.125" diameter magnet. (Most subs 7" deep or less will fit)
SWX-1043D:
Top-Mount Depth - 8.6"
Not going to work, plus the whole running all parts by same manufacturer (when not being paid to do so) is a dead giveaway of going with "style" over quality and function.
Are you after sound quality or excess volume?
If you're after sound quality, a subwoofer that'll give you great SQ for less - Sundown SA-10 (6" mounting depth).
If you're looking for a ton of SPL/max volume, you shouldn't be looking at a sealed enclosure at all, and since different subs need different ported enclosures, there's no generic box that'll work, so you'll have to get one custom made for the sub.
Old Dec 23, 2011 | 12:51 PM
Kissoon13's Avatar
Well my second option that I would like to go with would be the 2 10" Zenclosure box with two type-r's...the mounting depth on the subs are 5-7/8''...this should be good then right? And what's your opinion on the sub? I really appreciate your help.
Old Dec 23, 2011 | 04:21 PM
Type-R's are good price/performance woofers, but if output is your goal, go with a ported box, not dual sealed.
Old Dec 24, 2011 | 01:31 AM
Kissoon13's Avatar
Ok thanks for your help I will definitely take those options into consideration and your thoughts on the amp please?
Old Dec 24, 2011 | 01:45 AM
eggyhustles's Avatar
I wouldn't put an sa in a sealed box.
Esp a small flimsy one like the zen enclosure. They're great sounding subs, but more suited for ported enclosures.
If u wanna stick with alpine, go for the type r 8's.
Old Dec 24, 2011 | 03:43 AM
Kissoon13's Avatar
Why do you suggest the 8's?
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
zcherub
Sep 10, 2015 12:03 PM
Batfinity
Intake & Exhaust
Sep 9, 2015 09:21 AM
