No-Bose HU into Bose system
Old Jan 1, 2012 | 03:08 PM
BallerOnaBudget's Avatar
Just wondering if it's plug and play bringing the non-Bose HU (6-disc) into the Bose system? I can't find a definitive answer as to whether it'll work without modification, nor have I found pics of the back of the Bose HU to see how the connections are? Thanks in advance!!!
Old Jan 1, 2012 | 03:48 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
No. Definitively no.
The plugs will plug in, the signal wires are also in the same place, but the bose unit outputs a low-level differential-balanced signal on those wires, while the non-bose outputs a high-level unbalanced signal. You will have the same problem with audio signal that people who try and put an aftermarket unit into the bose amplifier without using a signal adapter like the PAC ROEM-NIS2.
Old Jan 1, 2012 | 04:02 PM
Thank you very much, I figured the PAC was gonna be needed, but thought I'd verify! Appreciate the help!
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
