USA SPEC PA15-nis DIY??
Old Jan 26, 2012 | 01:27 PM
lowkeeg35's Avatar
I just got the pa15-nis delivered and want to get this install started tomorrow. I only found a DIY for the inf version which was for a sedan with navi. I have a 2007 coupe w/o navi. If someone can direct me towards a diy or explain to me any difficulties i may encounter it would be much appreciated! Thanks in advance.
Old Jan 26, 2012 | 02:09 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Remove the radio out outlined in the double din install resources sticky, plug the adapter in, run the wires to where you want your iPod and replace the radio.
Old Jun 9, 2013 | 01:49 AM
Phantastik's Avatar
I just installed this unit today, everything works fine, EXCEPT it doesn't charge my ipod classic/ iphone 4s. Please help!
Old Jun 9, 2013 | 04:22 PM
The Stimulation's Avatar
Phantastik, are you using the ipod cable or the auxiliary (black and white rca plug one end and headphone jack on the other?)
Old Jun 9, 2013 | 04:35 PM
Phantastik's Avatar
I am using the black ipod cable that comes with it.
Old Jun 9, 2013 | 04:54 PM
JaE35's Avatar
Moderator
G35 Sedan
http://usaspec.com/product.php?Produ...eShowProduct=1
go read the manual at the bottom, goes over everything
Old Jun 9, 2013 | 05:08 PM
Phantastik's Avatar
Thank you, I do have the manual and did read it. Everything else works fine- steering wheel controls, track name etc. But it won't charge, is it maybe because I grounded the ground wire wrong? I grounded it to a screw on a bracket that holds the radio.
Does your guys USA Spec charge your device?
Old Jun 9, 2013 | 05:10 PM
JaE35's Avatar
Moderator
G35 Sedan
Mine does, i grounded it on the back of the cd player..have the INFI and first gen ipod touch
Old Jun 9, 2013 | 05:16 PM
Phantastik's Avatar
Hmm maybe I've grounded it wrong? Ugh it's such a pain to take everything out again blahh
Old Jun 9, 2013 | 05:38 PM
JaE35's Avatar
Moderator
G35 Sedan
had to pull mine out 3 times til i got it right lol
Old Jun 9, 2013 | 05:53 PM
Phantastik's Avatar
Ouch, then I might have to pull it out again then. I am sure you don't have a picture, could you give me a very detailed description of the location you grounded yours? I'd appreciate it!
Old Jun 9, 2013 | 05:57 PM
JaE35's Avatar
Moderator
G35 Sedan
Sorry I don't have any pics but i mounted it to a screw on the back side of the radio not the side if that helps...any metal should be fine honestly, email their support those guys are great
Old Jun 9, 2013 | 06:17 PM
Phantastik's Avatar
Yeah that's what i mounted it to. I will contact them tomorrow. I was checking with the forum to see if you guys had any quick fixes.. Thanks!!
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
prinny
Nov 22, 2015 11:07 PM
