Annoying whistling noise
Old Feb 12, 2012 | 11:22 AM
dfano16's Avatar
I have been having this problem for a couple of months now and i cant figure out what to do about it. a high pitched noise comes out of my passenger side tweeter almost every time i start my car and continues through the rest of the time i am driving. the noise get higher pitched when the RPMs get higher. it is very annoying and i need some help on what to do. if anybody knows what this is called or has any clue on what to do i would appreciate it.
Old Feb 12, 2012 | 12:22 PM
Ray Ray's Avatar
Sounds like a ground issue. Do you have a pioneer head unit?
Old Feb 12, 2012 | 12:25 PM
dfano16's Avatar
i have a kenwood head unit and a pioneer sub
Old Feb 12, 2012 | 01:24 PM
bigc's Avatar
Wings Nation
sounds like alternator whine.
Old Feb 12, 2012 | 01:27 PM
dfano16's Avatar
do you have any idea on how i go about fixing it?
Old Feb 12, 2012 | 01:34 PM
bigc's Avatar
Wings Nation
As Ray mentioned above, its a ground-related issue. You'll find lots of information on this online as this is a fairly common problem.
Old Feb 12, 2012 | 02:27 PM
Ray Ray's Avatar
Here's a good site to check out and i believe it may have same problem as yours. http://www.caraudio.com/forums/wirin...ine-issue.html There can be several factors that i can think of for your tweeter to cause that whine. When i had a pioneer headunit installed in my integra along with an aftermarket subwoofer i did get that whine as well. Here are a few things that i can think of that is causing that whine:
1. RCA's. Do you have the power wire and RCA's ran on the same side? If so this will cause your speakers to generate engine noise. The proper way is to run the power wire on one side and the rca's on the opposite side.
2. The headunit itself is causing the whining noise. Here's a temporary fix which i tried and it did work as well. http://www.hondacivicforum.com/forum...x-*56k*-75438/
3. Replace the headunit or amp.
Hope this helps.
Old Feb 13, 2012 | 08:50 PM
saywat?'s Avatar
i wouldnt bother too much with the power and rca running on the same side possibility. ive done that to all my cars out of laziness and have never had that issue lol
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
AJC128
Nov 1, 2015 11:55 AM
dcsbh1
Oct 1, 2015 03:15 PM
