amp connection
Old Mar 7, 2012 | 01:35 PM
007JD's Avatar
amp connection
when i had done my system i did this
https://g35driver.com/forums/audio-v...se-system.html
but im chnging out my radio to a double din
but keeping my bose speakers
should i leave my bass amp connected using that method above or should i just wire my bass suub to directly to my new double din in the back
which will sound better thanks
Old Mar 8, 2012 | 12:34 AM
Top Teke's Avatar
I'm not sure what the link you listed leads to cause I can't load it for some reason, so I'm not exactly sure what you mean. But it sounds like you added a sub to your stock Bose system.
If you're swapping head units for an after market now one all you need to do is:
- wire up your amp with power to the battery, ground to the chassis, remote and rca's to the deck
- speaker wire from the amp to your sub(s)
- have a look at wrathernaut's resource list, the very first sticky in this forum, for a list of other necessary parts and how-to's regarding using them.
Hope this helps!
Old Mar 9, 2012 | 04:36 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Wire your sub directly to the new headunit, it'll sound WORLDS better by bypassing the bose amp.
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
