Another possibly stupid question..
Old Apr 3, 2012 | 12:21 AM
Top Teke's Avatar
I hadn't thought of this till now, but if I'm installing a receiver that's bluetooth enabled will I have to use the provided microphone for cellphone conversations or is that what the mini 1/8" jack on the Metra Axxes SWI is for?
Old Apr 3, 2012 | 01:24 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
The Axxess ASWC doesn't do anything with the microphone.
Some cheap units have built-in microphones, but most will include an external mic you run yourself.
If your car had factory bluetooth, you can theoretically re-use the factory mic, but you'll have to splice the wires into the mic wire/jack from the headunit's microphone.
Also if you had factory bluetooth, you have to bypass the factory bluetooth box for the steering wheel controls to function through the Axxess ASWC.
Old Apr 3, 2012 | 01:28 AM
Top Teke's Avatar
Does that mean I should've got the PAC SWI?
Old Apr 3, 2012 | 08:26 AM
4 Door Skyline's Avatar
Negative Top, you definitely got the right unit, the PAC unit is inferior to the Metra unit (hard to believe, right? Lol)
Old Apr 3, 2012 | 12:00 PM
Nope, the problem is with the factory bluetooth unit, since it is given first priority on steering wheel signals, so you have to change that by wiring around it.
Old Apr 3, 2012 | 03:04 PM
Top Teke's Avatar
Okay. I totally overlooked this. How do I wire around it?
Old Apr 4, 2012 | 01:16 AM
The telephone adapter is in the trunk, driver's side on the floor.
There's the large harness going into the telephone adapter in the trunk. In the very center are a green and red wire with a yellow right next to them. There is also green and red and yellow wires just to the side of the center. Connect the red to the red and the green to the green and yellow to yellow.
That's it.
Old Apr 4, 2012 | 02:00 PM
Top Teke's Avatar
Okay awesome. I've been noticing that my phone and receiver disconnect from bluetooth here and there - do you think this could be contributing to it? I guess we'll see as soon as I'm done..
Old Apr 4, 2012 | 04:38 PM
Top Teke's Avatar
Wrathernaut, it looks like these are the first 3 wires you are referring to. Just double checking.
Old Apr 4, 2012 | 06:41 PM
Top Teke's Avatar
Hmmmm.. This is what I did
I don't think I did it correctly. Now the left-hand steering wheel controls don't work at all. Please advise.
Old Apr 5, 2012 | 04:37 AM
It looks correct from here - can you show your connections and where you've grounded the yellow wire at the back of the radio?
Old Apr 5, 2012 | 07:06 AM
Top Teke's Avatar
I'll be pulling the radio again when I finish the backup camera install so I'll snap a few pictures then. But I grounded everything from the back of the radio to the same 10mm bolt. Its one of the 4 around the shifter ring - I used the bolt in the 10 o'clock position.
Old May 28, 2012 | 03:30 AM
lij1's Avatar
sooo connecting those wires will give the ability to have the bluetooth button on the steering wheel?
Old May 28, 2012 | 06:14 AM
Yes, bypassing the factory bluetooth adapter lets you use the buttons on the steering wheel for whatever you want that the radio supports.
Old Jun 4, 2012 | 06:44 PM
lij1's Avatar
i did this and the mode button doesnt work and the phone button is my source now, is this whats supposed to happen?
