need new alternator?
Old Apr 19, 2012 | 12:07 AM
Alec's Avatar
currently I have one sundown audio sa-8 powered by a Hifonics brutus 1200w amp. I'm debating on getting another SA-8. I've been told that i'll need to get another battery, he suggested this-
Amazon Amazon
My question is if i'll have to get a new alternator also. I know that charging 2 batteries puts more strain on it, and if im going to have to get a new one too I don't know if getting another sub is worth it. I'm giving the sub about 500w or so, so if I get another it should be around 1000w max. Thanks guys!
Old Apr 19, 2012 | 02:02 PM
Top Teke's Avatar
No. Unless you're adding another amp for the new sub adding a battery would be overkill.
If you're really worried, upgrade your battery+ to alternator+ cable, your battery(-) to chassis cable, and your engine ground to chassis cable. Google "big3 upgrade."
Old Apr 19, 2012 | 03:49 PM
Alec's Avatar
yeah I've heard of the big 3. I'll probably just go ahead and buy the new sub w/o a battery and see if my lights dim or anything. thanks
Old Apr 19, 2012 | 04:10 PM
Jaemitch's Avatar
An easy way to find out if your gonna need a new alt is to make a list of all the accessories that will be running at one giving time and add up all the amps they pull together, then add the amps your amp is gonna be pulling, then subtract that from the amp output of the alt and that will give you what you have to play with.
Old Apr 19, 2012 | 06:40 PM
Alec's Avatar
alright will do!
Old Apr 19, 2012 | 10:27 PM
Top Teke's Avatar
Good luck with your install Alec, be sure to post pics!
Old Apr 20, 2012 | 10:19 AM
blazeplacid's Avatar
I would say wait till you get your stuff installed and go from there.
I run a nine.1 and a rockford 300-2 and get not dimming, strain, or any other kind of issue.
I run my set up pretty much full tilt with the roof flexing and have had no issues with the stock alt and a mid grade battery
brianuc4
19
Apr 10, 2020 02:12 PM
Thebaws11
Nov 30, 2016 12:54 PM
BradMD_96
Oct 6, 2015 09:31 AM
sullivan72
Sep 22, 2015 11:39 PM
