New speekers with factory Bose
Old Apr 24, 2012 | 01:44 PM
Gdriver90's Avatar
I have an 06 coupe with Bose and NAV, i already have a sub setup that i like.
i want to keep the stock head unit because it look clean. im considering doing infinitY kappa series for the doors and the rear sides.
Question 1: is is it safe to use factory amp? (i have heard that the bose amp isnt designed to handle other speakers and what it could over heat and crap out)
Question 2: if that not the case would it be really gaining anything by just swapping out speakers and using factory Bose amp
Old Apr 24, 2012 | 02:33 PM
cninham's Avatar
When starting out I had similar requirements as you. I selected the following speakers:
FRONT DOOR
Infinity Kappa 62.9i (coaxial), 75 Watts RMS
Infinity Kappa 60.9cs (component), 90 Watts RMS, 2 ohm
REAR SEAT SIDE PANEL
Infinity Reference 6032si (slim profile), 60 Watts RMS, 2 ohm
REAR DECK
Infinity Kappa 692.9i, 110 Watts RMS, 2 ohm
These speakers work just fine with the standard Bose amp and was a relatively easy swap/replacement. The Bose amp is a little under-powered for the speakers, and does not do the speakers any justice, but they definitely are an improvement over the factory/OEM speakers. Also, there are better speakers out there, but I originally opted for these speakers because they were 2ohm and a easy replacement for the existing factory/OEM speakers.
Now, I will continue to add that following the advice and recommendation of Wrathernaut and Top Teke I have recently elected to replace the Bose amp with a JL XD600/6 amp -- I have not yet gotten to do the upgrade, but it is on my to do list (as soon as I find the time)
Please be aware that I am NOT an audiophile, and I am not an audio system expert, and I do not have the discerning ears of some of the "fanatical" members on this forum. My project started out as a simple replace the head unit as it was defective. Then I wanted to replace the speakers just to have something "better than the factory sound system." Now I am replacing the amp. If I seeked and followed the advice of the knowledgeable members on this forum first I would have (1) replaced the head-unit (radio) first and (2) the front speakers with a set of high end speakers and a good aftermarket amp next. Don't upgrade the rear seat side panel speakers, and if you "want" you you can upgrade the read deck speakers later or replace/install with a good sub.
I hope this helps.
Old Apr 24, 2012 | 04:04 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
The worst part of the factory system by far, is the bose amplifier. If you're looking for better audio quality, replace that first.
If you have a subwoofer, remove the rear deck 6x9's and leave the openings open to allow the bass to travel from the trunk sub into the cabin freely.
Put some solid components up front (kappas are a bit bright - good for a noisy car, but not the best for ours). Budget-wise, I'd start with Phoenix Golds, from there, Polk Audio, then up to Boston Acoustics Pro60se's (what I have), and beyond that, there's Focal and other really expensive ones.
Uh, anyway your questions.
1) Yes, it's safe to use the bose amp with most anything, best-case scenario, you blow it out and replace it with a real amp.
2) No, you're not gaining much by just swapping speakers. You're increasing potential quality, but with that amp there, you're not going to get much out of them.
Old Apr 24, 2012 | 04:14 PM
Gdriver90's Avatar
if i swap out the factory amp, what the best way to do that? im running an MTX re-q for the subs right now. and my main source of audio is coming form a PXamg adapter connected to my ipod
Old Apr 24, 2012 | 05:05 PM
Top Teke's Avatar
Check out this sticky.
That MTX unit seems like a band aid solution - no offense. I'd sell it and put the money toward replacing your factory components. Like cninham and Wrathernaut said - start with the amp and you'll start getting more our of your system.
Old Apr 24, 2012 | 06:36 PM
Gdriver90's Avatar
i already have a amp and sub setup, im just not sure the best way to add a 6ch amp and get it all wored up peoperly to the bose.
Old Apr 24, 2012 | 07:17 PM
You'll need to read the first post or two on this sticky as well:
https://g35driver.com/forums/audio-v...-stock-hu.html
Not all amps can take the balanced signal (JL does, and has a couple 6-channel amps).
Old Apr 24, 2012 | 11:10 PM
sandaluv's Avatar
hey wrathernaut, i see you recommended polk. i was just looking at some at frys today. polk mm6501 this must be their higher end line. $229 for those components. is this what you had in mind? what about the polk db6501s for bout $120. very well reviewed buget speaker. what can you tell us about these polks. thnx
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
TurTLe*
Sep 29, 2015 01:43 PM
