Pioneer -- "Caution: screen image may appear reversed"
Old May 9, 2012 | 02:19 PM
cninham's Avatar
OK, before I start getting flames telling me this is an Infiniti forum, that I should search the forum and/or Internet, or call Pioneer -- I have done all of the above and have not been able to get an answer. Pioneer could not help me either. I am hoping some of the brain-power on this forum might have an answer for me...
Vehicle is an 2003 Infiniti G35 Coupe. I have a Pioneer AVH-P3400BH DVD multimedia receiver. I have connected the Pioneer ND-BC5 rear view camera. I have used the purple wire behind the drivers kick panel for the "reverse sensing" of the back-up lamp / lights.
Everything works fine. When the car is turned on (either ACC or ON with engine running) and I put the car in reverse then the radio switches to the rear view camera display and I see the reversed (mirror) image. I also see a message that states:
Caution:
Screen image may appear reversed
This message stays on regardless of the duration of viewing the rear view image and does not go away after some period of time. Is this standard operation?
Is there some way to disable this warning/caution message...???
Thank you -- Cameron
Old May 9, 2012 | 02:35 PM
Bastone's Avatar
This is just a disclaimer from Pioneer, saying that depending on which camera you have, the image displayed on the screen will be reversed.
Nothing serious.
It's like when you put most new cars in reverse, the Navi screen will show the backup camera image, but it will also show a disclaimer at the bottom saying "Check surroundings for safety" or "Turn and look before backing".
Old May 9, 2012 | 02:45 PM
cninham's Avatar
he he he -- I know (understand) that it is a disclaimer, but it is ANNOYING and sometimes it "obstructs" the object(s) that I am actually trying to view. I want to remove the message, if possible, or at least make the message disappear after displaying for a short duration.
Old May 9, 2012 | 02:49 PM
EbbAndBlow's Avatar
It is not possible unless you are a software engineer and are able to hack the on-board software to re-write some of the code. If it was possible any other way, there would have been an option in the menu system. But I doubt pioneer would put something like that in there since it is a disclaimer and could end up costing them a crap load of money in lawsuits.
Old May 9, 2012 | 03:49 PM
Golden_Shower's Avatar
I have the same car and AVH-P4300DVD with Audiovox Car ACA200W and I get no disclaimer what so ever when I put it into reverse.
Old May 9, 2012 | 09:52 PM
blazeplacid's Avatar
its the same with any in dash navi
you have to "accept" the warning to do anything with the navi.
Just the way the lawyers cover the company.
Old May 10, 2012 | 01:35 AM
Top Teke's Avatar
If you ever find a post to this please post it, I'd like to remove that from my screen as well. Don't let the man tell you how to live your life..
Old Jul 1, 2016 | 02:34 AM
Arco's Avatar
How to solve this issue? I have pioneer avh 1450dvd and thosr word stilll showup in the screen
