Amp Gone Bad
Old May 12, 2012 | 02:47 PM
lostsummit's Avatar
Amp Gone Bad
I have an 05 Coupe with the "premium" Bose system and navigation. Recently I have been having trouble with what I believe is the amp. Lately, when starting the car, (about 50% of the time at first.) the stereo starts fine, will play CDs and picks up radio, but I get no audio from the speakers. (no audio from the nav system either). In the beginning, I could turn off the car and back on, and chances are it would come back, and work until the car was turned off. But it has been getting progressively worse. Now it has completely stopped working.
I am guessing that the amp is the problem. Any ideas or suggestions on what I can do? I done i plan on selling the car soon, so I dont need any better then stock, but I do need to fix it. I see oem amps on eBay for $200, but is there a cheaper alternative?
Thanks for the help!
Brandon
Old May 12, 2012 | 07:42 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
I'd keep an eye on the marketplace here. Just make sure you get a coupe amplifier, as the sedan is 5-channel vs. the coupe's 6-channel.
Old May 13, 2012 | 07:35 PM
Mikebielz's Avatar
ill sell you my oem amp. i have an 06 coupe text me i never come on here 5164573468
Old Jul 6, 2012 | 02:58 PM
adman101's Avatar
i am having the same proeblem...no sound at all. did you find a fix? the amp or HU?
Old Aug 1, 2012 | 04:10 PM
Rippin6Gears's Avatar
Bump this thread then making a new topic... How can we test the amp to see if it's bad? No sound but everything works normally.
Old Aug 1, 2012 | 04:36 PM
If the radio functions as usual, get a multimeter and check the power and audio signal wires at the harness that goes into the amp. If they're all giving good signal, that pretty much leaves the amp as the problem.
Old Mar 8, 2026 | 10:23 PM
robbrower's Avatar
is that offer still available?
g.spot
May 9, 2016 10:54 PM
ZoominG35
Audio/Video/Electronics
Oct 12, 2015 04:53 PM
reaper76
Sep 20, 2015 11:59 AM
JustinMKN1
Sep 18, 2015 03:40 PM
