Audio problems... please help audio gurus!!!
okay well first of all, I'm a long time peaker and recently became a member
... Just wanted to go ahead and thank the G community for all the help and diy that everyone has posted ...
okay so my passanger side door speaker and tweeter are not working, i have search here on the forum and found some info but nothing help, It does not play on either Cd nor tuner soo my question is has any had this problem on a NON BOSE?
I pulled the head unit and everything seems to be fine
Checked all the wiring from the tweeter and speaker and everything is okay
could it be a fuse?
... Just wanted to go ahead and thank the G community for all the help and diy that everyone has posted ... okay so my passanger side door speaker and tweeter are not working, i have search here on the forum and found some info but nothing help, It does not play on either Cd nor tuner soo my question is has any had this problem on a NON BOSE?
could it be a fuse?
Not a fuse.
If it's not a bose system, all that can really be bad are the headunit, wiring, or the speaker.
Swap the left/right door speakers to see if the speaker's the problem, while the door panel's off, use a multimeter to check the wires. Beyond that, it's likely the headunit.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
FS[SoCal]: D/S 4080 Enclosure & JL Audio W6v2 10 inch
MrIP35
Nov 8, 2015 10:47 AM
