New Here
Old Nov 2, 2012 | 08:23 AM
Port55's Avatar
New Here
Forgive me, I'm doing my best to search and will continue to search, but I was hoping someone can give me some advice based on experience. I just bought a mint condition '07 G35 coupe and I love it. Except for the system.. I'm kind of a stereo enthusiast and I am so very disappointed in the sound of this car. I have premium sound with the Bose set. I honestly don't want to go wild with this system as I have spent thousands in the past on my previous vehicles. I would like to keep the stock radio and I guess I should say that I really like highs and with this car a little base will suffice. I may be able to even bare with the stock 6x9's depending on what it sounds like if I replace the rest of the speakers. I am not opposed to separates all though I want to stay as close to the stock setup and sizes as possible. I believe they call for an odd size if I'm correct. I'm hoping to not have to buy an amp to power the speakers if possible. I have to admit, my wife has a 2010 Lexus is250 and her stock system sounds really good. I don't mind spending a little $$ if I can get it to sound really clean. Anyone who knows stereo's should know what I mean by "clean". I'm hoping to not have to cut anything as I would like the air space to be as sealed as I can get it, although like III said I am open to advice to get what I want. I apologies for the long post and I should have spent more time searching but it's late some I'm hoping someone will throw my a bone here lol. I will continue to search but thanks in advance for any input, and will be appreciated. Thanks -Tim
** to be honest, I'm not even really sure what speakers or how many are actually stock in the car lol
Old Nov 2, 2012 | 09:53 AM
broke_as_ajoke's Avatar
I wish i could help out with ya question about keeping the stock radio. I just replaced my non-bose system.. I know u have 6.5 component speakers in the front (and I think the same size is in the rear on the side). From help from the guys on here.. U might want to replace the bose amp with an aftermarket amp and get a sub for the trunk. That will give you the bass you are looking for. Once you heard it, you will probably disconnect the 6x9 in the rear deck. There is a tread about replacing the amp and keeping the HU, but u going to spend money on the lil parts that are needed to connect to the aftermarket amp and sub. The link is below
https://g35driver.com/forums/audio-v...g35-coupe.html
Old Nov 2, 2012 | 01:03 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Read through this post here:
https://g35driver.com/forums/audio-v...-stock-hu.html
Keeping the the stock bose headunit raises issues with the balanced audio signal it produces, but otherwise gives you a clean signal to work with so long as you get it before the bose amp. These cars are quite well-designed to upgrade the system and look stock:
Here's the upgraded 6.5's and tweeters in the stock locations:
0 gauge wire runs just fine along the passenger side to the trunk:
And a simple shelf and good enclosure make this the only visible part of the install:
Old Nov 3, 2012 | 12:56 AM
Port55's Avatar
Thanks for the reply guys. I'm mainly more concerned with the front and rear side speakers. What model did u go with? Also were they just separates or components and added additional tweeters? Thanks again.
