Signal Summing or LOC required, horrible sibilance?
Old Dec 18, 2012 | 02:07 PM
releasedtruth's Avatar
Alright, here goes the short version.
Using an Alpine PXE-H650 Imprint tapped off the front speaker leads prior to BOSE amp (gone) and into the AUX input on the Imprint.
Works fine, gains on amps aren't high, but I cannot tame out some brutal sibilance and harsh guitar frequency. Have the Imprint set to max volume so I can use HU controls (never above 20).
Curious if I need a LOC to amp the signal prior to the Imprint or SSI in case I'm missing some frequencies by only using the front speaker outputs.
Have swapped mids/tweeters up front, same frequency pain occurs. Current are Image Dynamics NX30s and Dynaudio MW160GT crossed at 2k (have tried many CO points)
TL;DR - Can a LOC fix sibilance that may come from a poor HU signal?
Old Dec 28, 2012 | 10:23 PM
Okay, I've been doing a little research and I'm not sure if wiring in the RCA to speaker leads is the issue.
I basically bared wire on the front speaker wires before the BOSE amp and spliced into (soldered) Acoustic Research PR-131 RCA into the Imprint. It's shielded and I don't notice any noise, but someone that's RCA'd into an amp or DSP with experience would be appreciated.
Old Dec 29, 2012 | 01:22 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
The Bose headunit outputs a differential balanced signal, otherwise, it is a clean signal. I gave the product page a look, doesn't look like converting balanced to unbalanced is one of its features, so it is probably doing some really strange things to try and compensate, since a clean balanced signal looks like a really bad unbalanced one.
This post would be of much use to you.
https://g35driver.com/forums/audio-v...-stock-hu.html
Old Dec 30, 2012 | 10:29 AM
Very good to know, thanks. I'd spliced in this way based on some successes on the board with similar setups. Is there a better method I should explore? I could always wire directly into the speaker level inputs and go through the signal flattening procedure on the Imprint, but figured that was pointless with a clean signal.
That thread is where I got the information on the RCAs. I used to have a JL 500/5 that accepted differential balanced, but the Alpine does not and the staging created by the Imprint is hard to beat. I loathe the idea of pulling the dash apart to add a LOC to RCA in so I may have to go through the ANTeq setup to try that.
Old Dec 30, 2012 | 06:59 PM
If you're that concerned about quality audio, I'm surprised a new headunit isn't 1st on your list. That'll definitely open up your options on amp and processor. Plus, since the factory headunits are so failure-prone, it's a good way to prevent failure in the future.
Old Dec 30, 2012 | 10:10 PM
Certainly a valid point, but an extra $1000 for HU and finisher, plus taking the dash apart does not sound like a project I'm willing to take on. Pre-kids, would have been no problem
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
dcsbh1
Oct 1, 2015 03:15 PM
Detailed Image
Sep 28, 2015 07:04 AM
