stock amp troubles :(
Old Jan 24, 2005 | 04:42 PM
dicosmo's Avatar
im not very firmiliar with car audio but i decided i was going to do the double din conversion, add a mono amp, a 4 channel amp, and a sub, and keep my interior speakers stock for now... but when i intended to remove the stock bose amp and take out the speaker wires and plug them into a new amp the damn thing is wireing harness' insted of speaker wire... is there any way to hook up the new amp without running new wires?
Old Jan 24, 2005 | 06:17 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
just hack the harness.....use the existing stock speaker wire to connect your amp to the stock speakers.....
do a search on here and there is a wiring diagram for the color-coded speaker identification....
doc
Old Jan 24, 2005 | 08:41 PM
dicosmo's Avatar
so basically just cut the clip off and that is speaker wire?
Old Jan 24, 2005 | 08:45 PM
MorenoEnNYC's Avatar
Dude if you're asking a question like that maybe you might want to have a professional do the job!
Old Jan 24, 2005 | 09:12 PM
dicosmo's Avatar
why... once you figure out what to do its not hard to do
Old Jan 24, 2005 | 09:25 PM
sorry but I was being sarcastic
Old Jan 24, 2005 | 09:32 PM
dicosmo's Avatar
lol sorry thought u were tryin to be a tough guy and kidna hurt my feelings
Old Jan 25, 2005 | 11:18 AM
sillief00l's Avatar
If you don't want to hack your existing OEM sires apart, you can still use one of two methods to connect your aftermarket products:
1) Use a speaker harness adapter like the one here: http://www.cardomain.com/item/MET727400
2) Use automotive T-Taps to tap into the existing OEM wires and run your own normal speaker cable from them.
Old Jan 25, 2005 | 03:51 PM
CLS2G35's Avatar
If you do hack don't hack too close to the plug, You may want to reconnet the harness in the future.
Old Jan 25, 2005 | 05:24 PM
dicosmo's Avatar
thanks the speaker harness sounds like the best bet i think ill give that a shot
zoop425
Mar 29, 2016 05:51 PM
broke_as_ajoke
Nov 6, 2015 11:49 PM
Bean_VQ35DE
Aug 22, 2015 09:56 PM
Thunderaan
Jul 22, 2015 07:40 PM
