My amp blows its fuses everytime I try to connect the power wire
Old Feb 5, 2013 | 09:18 AM
JasonT36's Avatar
Ok so I'm trying to hook my amp up to my car for my d250 and everytime I connect the power wire to it, the fuses in the amp blow. If I connect the power first and then try to put the fuses in they blow before they even get put all the way in. I checked the power wire and ground and it doesn't look like anything is wrong with them but I'm not very experienced. I just need to know if anyone knows what the problem is and how I can fix it. The amp isn't a sub amp
Old Feb 5, 2013 | 12:57 PM
NMG-4's Avatar
check the wires,all amps need 3 wires
(-)ground
(+) power direct from battery
(+) power remote control
Old Feb 5, 2013 | 01:39 PM
Duriisimo's Avatar
Amp is toast!
Old Feb 5, 2013 | 03:41 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Does it do it when no speakers or woofers are connected?
If so, amp is toast, or you're wired wrong.
Old Feb 5, 2013 | 06:56 PM
JasonT36's Avatar
Ok i just got a new amp from my friend and it turns on now. the only problem is when i connect my d250 to it, the d250 doesnt play any music and just makes a weird noise. my friend was using the same amp for his d250 and it worked. heres a video of the sound.
nettcar
Aug 25, 2024 11:59 PM
willdogs
Dec 8, 2015 11:32 AM
broke_as_ajoke
Nov 6, 2015 11:49 PM
Danielek
Aug 11, 2015 09:33 AM
Thunderaan
Jul 22, 2015 07:40 PM
