Help with Audio System
Old Feb 15, 2013 | 03:22 PM
dukehotty's Avatar
Thumbs up Help with Audio System
Hey guys, I am interested in upgrading my sound. I have been very, very happy with the upgrades I have but want to step it up a bit. Since I tried to upgrade my stock bose sound, I purchased better speakers for it. Now I have a new HU and am just tickled. I listen to all types of music 50cent, Skrillex, Clapton, Jazz, Bieber, Soundtracks etc. I like the bass you feel before you hear it and the crisp plucking of a guitar string that stings my ears when cranked up. Here is my current set up.
HU is Kenwood DDX418
Fronts Boston Acoustic Pro60-SE 2-way (250 watt peak power)
Amp- Polk Audio PA330 MOSFET 75 Watts x 2 (2 Ohm) continuous power, 100 x 2 (2 Ohm) dynamic power, or 200 x 1 (4 Ohm) continuous power
Alpine sub SWE 1043 -250 watt
I will soon be installing Steering control, Second Skin Pro, and a Kenwood CMOS 200 camera. I figured it would be a good time to upgrade something while I was in there. I have an extra Alpine sub (bought 2 on clearance for 30 bucks each)but I am still looking for a passenger 4080 type box. BTW JK about Beiber.
My budget is about $500
I appreciate any help/suggestions and thank Wrathernaught and Eggyhustles for the guidance they have already given me!
Old Feb 15, 2013 | 05:13 PM
eggyhustles's Avatar
I would
Get more power to the front speakers
Put both subs in a better enclosure. Not a big fan of small sealed.
The ddx doesn't give u much in terms of eq, but another dd or even a processor is out of your budget.
Old Feb 15, 2013 | 05:19 PM
dukehotty's Avatar
Originally Posted by eggyhustles
I would
Eggy! Thanks for stopping by. More power meaning a different sub or adding another sub? I don't know what a processor is but I am going to google it now. I am stuck with the little sub boxes because I often put my seat down to transport things. Thanks!
Old Feb 15, 2013 | 05:29 PM
More power to the boston's.
They're somewhat power hungry & 75 x 2 isn't much.
It's expected, usually even normal to vastly exceed the long term power handling for a few miliseconds at a time in order to have a dynamic system.
Looking at some of the material I've looked at lately, a 50w rms system would need to be capable of a peak of 500w to remain true to the source material's dynamic peaks.
I've fixed plenty setup's by adding more power/getting the subs in a better enclosure.
Keep the subs you have now. They'd perform well in a good enclosure.
Old Feb 15, 2013 | 05:32 PM
dukehotty's Avatar
Can you recommend an amp that would have enough power for my Bostons and my sub/subs (if I add the second?)
Do you suggest I go with 2 amps?
Old Feb 15, 2013 | 05:34 PM
yeah, 2 amps would be better.
1 4 channel that can be bridged down to 2 channels for the front speakers & a 1 channel for the subs.
You can toss these amps under the seats
for the sub
http://www.ebay.com/itm/Vibe-lite-bo...item27cfc2d971
For the speakers
http://www.ebay.com/itm/SOUNDSTREAM-...item460485824c
Someone will grab that vibe audio amp soon(they're very sort after)..so i'd grab that asap if i were you.
Old Feb 15, 2013 | 05:39 PM
dukehotty's Avatar
for the sub
For the speakers
Do you think that vibe is worth buy it now with $50 shipping?
Old Feb 15, 2013 | 05:40 PM
Definitely.
Supply and demand with those amps. They were selling for 300-350+ a yr or so ago.
This is the same amp in a different case http://www.ebay.com/itm/ARC-AUDIO-KS...052342&vxp=mtr
Old Feb 15, 2013 | 05:43 PM
dukehotty's Avatar
Definitely.
Just bought it. You haven't steered me wrong so far but there goes almost half my budget!
Old Feb 15, 2013 | 05:44 PM
The soundstream is $83.
Still have enough left over for a custom designed enclosure.
Old Feb 15, 2013 | 05:46 PM
dukehotty's Avatar
Do you think I still need the other amp or will my polk now send enough powa to the Bostons now that the sub is going to have it's own?
Old Feb 15, 2013 | 05:48 PM
Not enough power
Old Feb 15, 2013 | 05:50 PM
dukehotty's Avatar
Is all this extra equipment going to mess with my car battery? I sometimes eat lunch in my car and watch movies or sometimes I go watch a movie at the drive in using my car stereo.
Old Feb 15, 2013 | 05:55 PM
At full tilt, it'll pull about 140 amps.
You should eventually upgrade the battery.
Old Feb 15, 2013 | 06:05 PM
dukehotty's Avatar
I went ahead and pulled the trigger on the other amp. For the price, I hope to hear a noticeable difference. Thanks again Eggy!
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
MrIP35
Nov 8, 2015 10:47 AM
BradMD_96
Oct 6, 2015 09:31 AM
