the stereo problem saga continues....
Old Mar 20, 2013 | 12:04 AM
nsfallen's Avatar
did a quick search and didn't see anything pertaining directly to my issue...
i bought an aftermarket head unit because my factory stereo kept cutting out, but now even with the brand new head unit it's still doing it
here's the issue:
power to the stereo is ALWAYS working- i can always see the display working, change stations, adjust volume, ect, but sometimes there is no sound that will come out of the speakers. i'll get in the car and sometimes it's fine for a week, then for a couple days every other time i start it i dont have a stereo
also when it does it it's not like one speaker stops working or something like that. it's ALL speakers go to no sound whatsoever.
turning the stereo off and back on doesnt work, turning the car on and off doesn't work, changing stereo modes or playing with the volume doesnt work
i'm thinking it may be the bose amp that's going bad? it's the only thing i can think of that would cause my actual stereo to always be fine (factory and aftermarket head unit as far as the display showing everything fine) and consistently take out all of the speakers and not just one or two
any thoughts?
**also on a side note in the last couple months the cars has decided to randomly shut itself off from time to time, and in the last couple weeks the "slip" light and "VDC off" light decide to turn themselves on randomly for days at a time with me unable to turn them off, as well as the parking brake light coming on and off when the parking brake isn't on....i had a 350z for 3 years with zero issues (and that car was a highly modified nitrous car) and i've known the previous owner of my g35 since he bought it new and it never had issues.... so i've always praised these cars for being reliable, but now it seems like the car is turning to ****....it's a 2003 g35 coupe that just turned 90k miles in case anyone was wondering
Old Mar 20, 2013 | 02:03 AM
dukehotty's Avatar
In for remedy.
Old Mar 20, 2013 | 11:41 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
here's the issue:
any thoughts?
Your side-note symptoms are commonly seen with (but not necessarily indicate) a low/failing battery. Low batteries can be (but not necessarily are) caused by a failing factory amp. Failing factory amps are the most likely cause for all your speakers cutting out... but the speakers cutting out could be something else - failing headunit, spotty wiring of the amp turn-on-wire, or a poorly insulated mute wire tapping metal in the car could also do it.
Old Mar 22, 2013 | 01:02 AM
nsfallen's Avatar
hmm...ya it's not like the speakers quickly go in and out either. it'll be 10min-3 hours of no sound, followed by a few days of sound. it shouldn't be the head unit tho because the only reason i bought my new kenwood hu was because 1) i hate the factory one and 2) i just assumed it was the culprit for the problem because it's acted up for a while now
Old Mar 22, 2013 | 09:59 AM
So probably the amp or one of the wiring problems mentioned.
Old Mar 22, 2013 | 10:49 AM
nsfallen's Avatar
well i'll check out those wires and see if i can see a problem.thanks!
Old Apr 16, 2013 | 06:02 PM
Mystroe99's Avatar
i'm having the same issues with my g. I thought it was the wiring at first so i redid all the soldering, checked the grounds and it still acts up. There will be days when it will work fine, but then i hit a bump on the road and the sound goes off, hit another bump sound comes back on. I'm thinking its the bose amp going bad. I am also considering buying an aftermarket head unit, but after reading this i might reconsider. Are you still using the bose amp with your aftermarket hu?
Old Apr 17, 2013 | 10:41 PM
Blue Dream's Avatar
I drove ttrank's car solo
The Bose amp seems to be a problem in a lot of sound issues. I'd recommend getting a new DD stereo and adding a good quality 2-4 channel amp to drive it. You'll be quite happy with the results.
Old Apr 18, 2013 | 10:47 AM
This is pretty much the solution to every problem with audio system.
Old Apr 18, 2013 | 12:31 PM
nsfallen's Avatar
i am still using the bose amp and i think it is probably the issue...except i dont want to replace it with another crappy bose amp, but all of the aftermarket ones that would work seem to be $350 minimum... sucks because im not trying to upgrade my audio system, i'm just trying to maintain AN audio system and have it work consistently
Old Apr 18, 2013 | 03:31 PM
Yeah, who knew luxury cars would be expensive to work on?
Old May 14, 2013 | 05:03 PM
Mystroe99's Avatar
I bought a used Bose amp on eBay, swapped out my old one with the new one. Stereo worked fine for 2 weeks then crapped out AGAIN. Here's my setup - the headunit connects to bose, bose outputs go into MS8 input, MS8 output go to two amplifiers. The reason i kept the bose is because it sounds really bad if i connect the headunit directly to the ms8. I assume its because the headunit sends a weak signal and the bose amplifies it.
This really sucks, i guess i better save for a DD setup. smh
Old May 14, 2013 | 06:16 PM
Get the bose amplifier out of the signal path if you have an aftermarket headunit, if you can't get an aftermarket headunit to work with the MS8 and produce good sound, either the MS8 is faulty, or whomever's trying to install it doesn't know how to tune.
wuzz-upp
Oct 3, 2015 04:21 PM
JoeMac
Sep 28, 2015 12:28 AM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
2014g35x
Sep 11, 2015 07:53 PM
