FS: Sirius XM tuner
Old Mar 25, 2013 | 07:29 PM
SoulGlo's Avatar
Sirius XM tuner
Sirius Tuner for sale. Comes with everything, which would be Antenna and brain and power plugs
SOLD
Old Mar 26, 2013 | 09:59 PM
langsbr's Avatar
Does it work? Ive heard there is/was an issue where they cant be activated once the trial runs out.
Old Mar 27, 2013 | 12:30 AM
SoulGlo's Avatar
Yes it works, i wish i knew what you were talking about with a "trial run". I never had a temporary membership.
You plug the unit in, a code scrolls across the screen(channel 00) and you call sirius and tell them you would like to subscribe. You tell them the code(you may be able to do it online) and then the system is programmed over the air.
Old Mar 28, 2013 | 08:06 PM
langsbr's Avatar
I have an 04 sedan - where does the unit connect? I thought it was in the trunk, but I'm not sure if my car is pre-wired for SAT. I have all the trunk trim out and didn't see a connector.
Old Mar 29, 2013 | 05:05 AM
SoulGlo's Avatar
Start with this info
This is the factory made satellite radio that will work with your exsisting radio unit. Before purchasing please check & see if you are pre-wired for this unit, for 2003 the VIN rages are as follows, (these go by the last 6 digits of your VIN):
Sedan VIN: 321894 & higher
Coupe VIN: 210827 & higher
2004 and up are all prewired.
See the white plug coming out of the rear, that is what you need to find. This is in the rear driver side of the trunk
Old Mar 29, 2013 | 08:58 AM
G2B35AGN's Avatar
PM sent
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
gatorglaze
Sep 19, 2015 12:06 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
wuppiedog
Aug 7, 2015 11:16 AM
