Sound deadening the coupe
Old May 10, 2013 | 02:38 PM
SergeantRed's Avatar
Order
Alright! Goodluck! Just remember not to skimp and take your time! It is a PITA and when you're crawling around in the trunk your back is going to feel it lol
Old May 10, 2013 | 04:33 PM
ErikTaylor's Avatar
Thank you sir. I'll post my progress.
Progress #1- they have shipped it. Waiting commences.
Old May 10, 2013 | 05:40 PM
I'd like to see it. Don't F*CK UP lulz just kidding it's going to look awesome
Old May 10, 2013 | 05:44 PM
ErikTaylor's Avatar
Thank you sir. I have my 4080 and w6 waiting.
I am a little confused about something. Will this or will this not help with road noise?
Old May 10, 2013 | 05:59 PM
Yes/no
It will help but it's not going to be dead silent. You should notice a difference if you do your whole car. Realistically, the firewall should be done too but that is a nightmare to some extent. You will notice it on the doors. I would also do some of the foam tiles or whatever they are that Wrath recommended and the expanding foam I recommended for maximum effect or keep it simple
Old May 10, 2013 | 06:25 PM
ErikTaylor's Avatar
Yea definitely not going to do the firewall. Wheel wells?
Old May 10, 2013 | 06:28 PM
ErikTaylor's Avatar
Also any specific foam?
Old May 10, 2013 | 06:41 PM
I don't know how to do wheel wells. If you get an answer I'd like to know too. As Wrath has stated use the foam made for windows as it's pliable and tape off holes too keep the foam inside.
Old May 10, 2013 | 09:55 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Yes, closed-cell foam.
Go here:
www.sounddeadenershowdown.com
Take 10 minutes to read what's posted there.
Old May 10, 2013 | 10:00 PM
I used about 1/2 of a CLD tile on each wheel well. The noise reduction depends on how loud your tires are. There's some factory vibration dampener already on there, but not as good as the CLD tiles from SDS.
Doing the doors made the biggest improvement in noise reduction that I noticed, since the doors are generally going to be the only thing between you and the wind noise of the cars beside you. The tiles on there also prevent the door skins from vibrating along with the upgraded door speakers.
Old May 10, 2013 | 10:49 PM
ErikTaylor's Avatar
Thanks Naut. I'll check it out when I get to a computer.
Old May 13, 2013 | 10:34 PM
ErikTaylor's Avatar
Go here:
How many cans and can I get this from Home Depot/lowes?
Old May 14, 2013 | 05:07 PM
Closed cell foam doesn't come in a can, it comes in a roll. You cannot get the quality you need from home depot/lowes.
Old May 15, 2013 | 09:15 AM
ErikTaylor's Avatar
Hey Naut,
Thanks for the post. However I think I miscommunicated what I'm talking about. I'm talking about the foam that I spray into the trunk door to help silence it. I think it was mentioned on the first page of this thread? I remember it saying something about window section of Lowes or something... wait one. Let me find it.
Old May 15, 2013 | 09:16 AM
  #30
ErikTaylor's Avatar
I used expanding foam inside my rear deck - pretty much any gap in the trunk got filled with it. If others are taking this on, use the stuff for around windows/doors, the minimal expanding that remains flexible. The regular expansion foam that dries hard has no flex after it's dried, so the vibration from normal driving (let alone the subwoofer) can cause it to start to break up. Also, do it SLOWLY, and don't try and fill entire gaps at once. Put masking tape over any holes or gaps it can possibly come out as well. It's nearly impossible to get the foam of of carpet, so remove or cover any in the area as well.
Naut, this is what I was talking about in my last post. Thanks.
