Dd
Old Oct 1, 2013 | 09:04 AM
infinityjohnny's Avatar
Dd
What is a double din?
is that i connector? I know it has somthing to do with the radio/ac issue.
Question if i get an aftermarket radio installed will that cure the ac/radio issue?
there are way too many threads on this with fixes but no straight answers.
Old Oct 1, 2013 | 11:49 AM
Urbanengineer's Avatar
Audio/video/electronics section.
/thread
Old Oct 1, 2013 | 12:23 PM
Never would have thought of that thanks for the tip!
Originally Posted by urbanengineer
audio/video/electronics section.
/thread
Old Oct 1, 2013 | 12:32 PM
GR6RR's Avatar
http://lmgtfy.com/?q=g35+double+din
Old Oct 1, 2013 | 12:36 PM
Thanks
Originally Posted by gr6rr
Old Oct 1, 2013 | 01:18 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
No it's a "standard" size of the radio, it's a size of a radio, it has nothing to do with the radio/ac issue, except that it's a size of the radio you can put in place of the factory headunit, yes but you need more than the radio. There's plenty of threads with straight answers. Start with this one: https://g35driver.com/forums/audio-v...urce-list.html
Old Oct 2, 2013 | 12:09 PM
So can you just tell me if i get a new radio installed with the dash kit if this solve the ac issue also because it's powered up by the radio?
Thanks
QUOTE=Wrathernaut;6820941]No it's a "standard" size of the radio, it's a size of a radio, it has nothing to do with the radio/ac issue, except that it's a size of the radio you can put in place of the factory headunit, yes but you need more than the radio. There's plenty of threads with straight answers. Start with this one: https://g35driver.com/forums/audio-v...urce-list.html[/QUOTE]
Old Oct 2, 2013 | 07:13 PM
Thanks
Yes, new radio w/dash kit will fix the climate control issue.
Old Oct 3, 2013 | 09:28 AM
thanks i appreiate that!
Now instead of me going to P.C richard's
anybody in Longisland N.Y. wanna side job?
Old Oct 3, 2013 | 12:56 PM
Look at his guide. You unscrew a few screws and the units out. Then you take apart the old stereo from the Front piece, swap pieces and back in it goes.
Old Oct 3, 2013 | 01:43 PM
Nice, Is it true you can only get the metra kit that was what P.C told me .
I thought you can order a different one and he said it only comes silver or black my int is a brownish color.
Old Oct 3, 2013 | 01:47 PM
GR6RR's Avatar
metra is your cheapest option, doesnt look as good as the oem dd kit.
I found my oem dd kit on the forums, used. saved a bunch of money.
Old Oct 3, 2013 | 01:49 PM
thanks i thought so i'm tryin to do as much research as i can before i do it getting cold out need heat soon!!!
Old Oct 3, 2013 | 04:26 PM
Come down to savannah, GA and I'll do it free (gas getting here is on you though). Weather's perfect down here
Old Oct 20, 2013 | 08:11 PM
TB35's Avatar
I need your help Wrathernut I've searched on here for a while about the HVAC/Radio issue and I have checked the fuses the a/c sensor as well as taking the connector ribbon from the cd to the radio its self off and nothing has changed I have nothing no steering controls no radio a/c blows on high on 60 non stop and occasionally changes from high to low? I have also checked to see if I had loose resistors and there is no sign of that on my circuit board what do you suggest?
