AVH-P8400BH Wiring help!
Old Dec 22, 2013 | 09:25 PM
NJHG35's Avatar
So I have recently purchased everything I need for the installation.
-PAC ROEM-NIS2
-JDM Double Din
-AVH-P8400BH
Everything from the list that was posted on here.
So I began installing and got to the wiring and got everything wired up
I used this wiring diagram
and I am receiving no power whatsoever. The HU is not powering up at all. The fuse is not blown. ZERO POWER.
What is wrong or what can I do? Am I not catching something or what?
I am sorta stuck at this point and don't know what to do! Thanks for the help!
Old Dec 23, 2013 | 07:53 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
-PAC ROEM-NIS2
-JDM Double Din
-AVH-P8400BH
To clear up the question in the photo:
The OEM-1 is the actual adapter. When you combine adapteR OEM-1 adapter with the NISsan wiring harness, version 2, you get part# ROEM-NIS2.
Where are you grounding at? Do you have a multimeter to check power at both sides of the OEM-1?
Old Dec 27, 2013 | 10:17 AM
NJHG35's Avatar
Finally figured out what was wrong, since you said something about the ground I decided to check it and that was the problem, the ground wasn't good enough.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
BfloG35
Oct 16, 2015 05:22 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
