Need help with replacing/upgrading BOSE head unit.
Old Jan 1, 2014 | 07:35 PM
JOKER's Avatar
CLUB MODERATOR
Hello gents and gurus of Audio section.
I need a bit help with replacing my BOSE HU. It finally went complete retard and needs to be sent off to bose heaven.
So what I want to do is to replace it with aftermarket unit and leave all the other audio components in.
Since I'm a total newb in audio department I was wondering if yall can help me to make a right decision with a head unit.
I want something that will obviously have no issue working with rest of the bose system (amp)
Something that will support wide variety of media files, have navigation built in (or have nav appls in android base system).
My own research led me to Parrot Asteroid Smart
http://www.parrot.com/usa/products/a...asteroid-smart
Can I get your opinion on whether this unit is something worth getting or if there is something else you can suggest.
Thank you all in advance.
Old Jan 1, 2014 | 11:12 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Any radio will work equally well with the bose amplifier, provided you use the PAC ROEM-NIS2, as recommended in the shopping list.
I'd avoid built-in navigation. Definitely inferior to smartphone navigation, and the premium it adds to the cost of a unit is significant.
The asteroid smart is getting more favorable reviews on amazon than the appradio3, it is actually capable as a standalone unit, and will work equally well with any smartphone or dedicated wireless hotspot that can provide it with a network connection. The appradio is seriously crippled without a smartphone.
If the asteroid smart drops below $400, I'll probably pick one up to replace my wife's aging Pioneer AVIC-X910BT. The appradio still feels a bit too limited right now.
Old Jan 2, 2014 | 10:40 PM
JOKER's Avatar
CLUB MODERATOR
Can you link me to the shopping list thread.
Question on steering wheel controls. What will I need if I go with Parrot unit?
Old Jan 2, 2014 | 11:11 PM
Urbanengineer's Avatar
It's a sticky at the top of this sub forum, and not sure on the parrots ability to work with metra's access. Check their website for aftermarket compatability.
Old Jan 3, 2014 | 12:53 AM
JOKER's Avatar
CLUB MODERATOR
question on a steering wheel controls.
As you can see on the back of the parrot unit there is a plug for steering wheel controls.
Will ASWC-1 have to plug in there, or I simply have to wire up the plug that comes with Parrot unit (not sure if one does) to the ASWC-1 and wire that into the system?
Old Jan 3, 2014 | 01:44 AM
ASWC uses a 3.5/2.5mm plug that is cylindrical like a iPod plug. It doesn't look like that :/
Old Jan 3, 2014 | 04:13 AM
JOKER's Avatar
CLUB MODERATOR
Old Jan 3, 2014 | 11:16 AM
Parrot NO LONGER requires the Unika steering wheel adapter.
EDIT: METRA AXXESS DOES WORK! You just need the AX-SWC-PARROT cable, which as of this writing runs $15 from crutchfield.com or $6 from sonicelectronix (out of stock as of this writing).
Originally Posted by https://devzone.parrot.com/boards/5/topics/show/1054
Warning
Upgrade to SW 2.1.4 must be performed without AXXESS Integrate steering wheel commands plugged to the unit
Favorites radio station will be erased
IMPROVEMENTS
Interface
Support steering wheel commands from AXXESS Integrate
GPS
GPS module firmware upgraded
Tuner
Improve of audio tuner quality (specific for USA)
BUG FIXES
Interface
Night mode detection if the headlights are activated before starting ASTEROID Smart
Download
ASTEROID Smart update firmware is available here
Originally Posted by http://contentdocs.installernet.com/documents/vehicle/10985.pdf
For Parrot Asteroid Smart or Tablet: Connect the ASWC-1 male 3.5mm
jack into the AX-SWC-PARROT (sold separately) female 3.5mm jack and plug the
4 pin end into the corresponding SWC plug on the radio.
The shopping list - as previously mentioned, "Check the stickies!" - https://g35driver.com/forums/audio-v...urce-list.html
Old Jan 3, 2014 | 06:29 PM
JOKER's Avatar
CLUB MODERATOR
sweet. thanks for the help guys.
I need to do a bit of searching on how to wire up the AXXESS, other than that I think I understand the process.
I wonder if update to 2.1.5 firmware for the Parrot has same requirements/warnings as 2.1.4 does as far as AXXESS goes?
Old Jan 3, 2014 | 09:38 PM
Dunno, but again, if the price comes down a bit more, I'll be getting both and giving it a go.
Old Jan 3, 2014 | 10:34 PM
JOKER's Avatar
CLUB MODERATOR
do it.
I'll suffer without radio for now till you give it a try.
Old Jan 3, 2014 | 10:57 PM
do it.
Might be a while, I'm a patient man.
Also, maybe something good may get announced at CES this year.
Old Jan 3, 2014 | 11:20 PM
JOKER's Avatar
CLUB MODERATOR
keep us informed, I'm a patient man too, my bose CD haven't been working for couple years now
Old Jun 28, 2014 | 02:17 AM
JOKER's Avatar
CLUB MODERATOR
Really interesting news came out of Google I/O
Their androidauto system should hit the market pretty soon. Lot's of aftermerket partners are working on it with Googe. Hope to see some good aftermerket android units after this.
I'll hold off on the parrot unit for now.
Old Jun 28, 2014 | 06:45 AM
Hatchman's Avatar
Sounds good, looking forward to what comes out on the market. subd
