2004 G35 coupe: aftermarket front speakers need spacers?
Old Feb 2, 2014 | 03:42 PM
Premiersole's Avatar
I'm replacing the entire sound system on my 2004 G35 coupe (Kenwood HU, Alpine 6-1/2" component fronts, Alpine 6x9 back and Alpine 10" sub). I was just trying to figure out if I'm gonna need spacers for the the front speakers. Here are the dimensions:
Alpine SPR-60C
Dimensions
Tweeter Mounting Diameter (mm): 37.9mm
Tweeter Mounting Diameter (in): 1-1/2''
Tweeter Mounting Depth (mm): 19 mm
Tweeter Mounting Depth (in): 3/4''
Woofer Diameter (mm): 165mm
Woofer Diameter (in): 6-1/2''
Woofer Mounting Diameter (mm): 136mm
Woofer Mounting Diameter (in): 5-3/8''
Woofer Mounting Depth (mm): 59mm
Woofer Mounting Depth (in): 2-3/8''
Crossover Size (mm): 63mm x 32mm x 24mm
Crossover Size (in): 2-1/2'' x 1-1/4'' x 15/16''
Excuse my ignorance but it's my first time doing this and just want to make sure I have everything needed before I start taking everything apart. Any help or info would be appreciated.
Old Feb 2, 2014 | 05:29 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Alpine SPR-60C
Dimensions
You need spacers. You can modify the stock speaker spacers, but they are pretty flimsy plastic that won't stand up to well-amplified speakers. MDF spacers are the way to go. Either cut your own or pick them up from zenclosures - http://www.zenclosures.com/Speaker-Spacers-s/36.htm
Old Feb 2, 2014 | 08:51 PM
Thanks for the response! Exactly what size would I need to order from Zenclosures?
Old Feb 2, 2014 | 11:56 PM
So closest without being too small to that which zenclosures does is 5.5" center hole.
Old Feb 3, 2014 | 02:06 PM
Thanks again! I really appreciate your help! One last question... I found these on Amazon:
http://www.amazon.com/gp/aw/d/B007ZQ...453704&sr=8-14
Just want to make sure these will work like the Zenclosures would since they're cheaper.
Old Feb 3, 2014 | 03:38 PM
They look like they'd work fine, but the don't look as sturdy as MDF. Just be sure you run some felt tape under those plastic ones, otherwise, that's a huge potential source of squeaks.
vmcarbuyer
Oct 12, 2019 12:42 PM
brycealbr
Aug 11, 2015 11:47 AM
laksjd84
Jul 24, 2015 05:12 PM
igking
Jul 19, 2015 01:12 AM
