G35 stereo overhaul and a few questions
Old Dec 22, 2014 | 11:39 PM
mastabassa's Avatar
Arghhhh I just realized the sub I have is the 4 ohm version, didn't even realize they made a 4ohm, does this change anything with the amp I need?
Old Dec 23, 2014 | 12:58 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Originally Posted by mastabassa
Oh I was under the impression I should amp the tweeters on a separate channel from what I've been reading about these speakers, I saw a few people say you really want to run 100w rms to get the full potential of the speaker, maybe I misenterprated and I'll just listen to you since you seem to know what your talking about
I've got about 150w going per side through the included crossover, and am happy with the results. You can always go for a bi-amp setup and use an external signal processor... but that's getting into the complicated side for people who really want to control every aspect of their system. For the other 99% of the population, you'll be happy with the "stock" setup.
Old Dec 26, 2014 | 02:54 PM
mastabassa's Avatar
Awesome, have everything ordered and just about to place my order from sounddeadenershowroom, how many of each will I need to do the front doors and trunk?
Old Dec 26, 2014 | 08:18 PM
You only need about 25% coverage, so even 3 tiles per door is enough. another 5-6 for coverage in the trunk and rear deck.
Old Jan 8, 2015 | 03:19 AM
Antfidel's Avatar
Some awesome advice here Wrathernaut, thanks!
I'm about to start upgrading my sound system and I wanted to do something similar that you have suggested in this thread. I was going to go with the the Image Dynamics front components and a JL JX360/2 amp. I also want to do the sub + mono amp, but that's down the line when I get more cash money. My question is if I should keep the rears and 6x9s working between the time frame of installing the components and when I finally get around to getting a sub?
Old Jan 8, 2015 | 08:24 PM
The Image Dynamics probably have more low-end than the stock 6x9's, but the overall sound *might* be better if you run a high-pass filter on the Image Dynamics so they can focus on the higher end of the audio spectrum while the 6x9's keep doing the low end they normally do. I'd not use the rear full-range speakers though.
Old Jan 8, 2015 | 08:38 PM
ScraggleRock's Avatar
I'd like to know what your system sounds like, Weather. All super fine tuned and what not.
Old Jan 8, 2015 | 10:31 PM
I'm not an audiophile or into competition audio, so it's probably less impressive than you'd think. I just know what you should focus on first.
I'd like to pick up an JBL MS-8 and go to town tuning it, but I know that I listen to the car while driving, but since I haven't done some layers of mass-loaded vinyl and closed-cell foam throughout the car, I couldn't hear the improvement over some minor tweaking of the EQ.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
simperformance
Jul 24, 2015 11:17 AM
mushu
Jul 15, 2015 03:55 PM
