Aftermarket DD install not working
Old Nov 2, 2015 | 02:28 PM
SrT4_OwNeR's Avatar
My buddy had a DD sitting in his garage for about 8 months that he got in on a trade with various other items. It's one of those cheap eBay all in one head units. Well a deal came up on craigslist with a guy who wrecked his G35 before he could install a DD, and he was asking $175 for the Metra Turbo 2 95-7605A unused, but my buddy got it for $100. He ran by wally world and picked up a scoche wiring adapter for the head unit and came over. We got everything wired up and when i pulled his radio/climate control assembly out, there were 4 pigtails coming out of the radio. But only 2 of them will go into the scoche adapter. I read that one of the other ones is for steering wheel control, and I'm not quite sure what the 4th pigtail is for.
Anyways, we plugged it all up, and before we put everything back together, we tried to turn on the head unit but it wouldn't come on. I does work, though, when i hook it straight up to the battery. Also, the head unit is getting power when the scoche adapter is plugged into the 2 pigtails that fit, because there is a red light coming from the cd slot. Are these scoche adapters not compatible with the g35 even though the box says so?
Old Nov 2, 2015 | 04:55 PM
SrT4_OwNeR's Avatar
Further info I forgot to mention: it's a 2005 G35. It's equipped with the Bose system. It's completely factory with no modifications.
Old Nov 2, 2015 | 06:39 PM
DeafBringer's Avatar
Everything you need to know about how to wire up aftermarket dd with a Bose system is in the very first sticky in this section. Check it out.
Old Nov 2, 2015 | 09:42 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Scosche makes about 300 different harnesses/adapters, so specifying which one you went with would help - but it should at least let the headunit power up if it plugs into the factory harness. Whether you get sound at a good level and quality is another story.
If you're showing power to the unit but it won't power up, you've probably got the constant power (yellow) connected, but the switched power (red) isn't connected right. Another possibility is that you're not grounded. The ground wire from the wiring adapters doesn't go to anything, the factory radio relies on using the chassis as a ground.
So, if you get the right adapter (PAC ROEM-NIS2 adapter instead of the scosche wiring harness) and wire it up correctly according to the sticky that DeafBringer mentioned you should be good to go.
Old Nov 2, 2015 | 10:48 PM
SrT4_OwNeR's Avatar
Thanks for the input. I checked it out already. My initial question about the scoche harness wasn't addressed in that thread, which is why I started this thread.
It's the NN032 harness. It says on the box that it works with 03-06 G35. I will let him know to take this back, if they will take it, and get the PAC harness. Thank you.
DG2Door
Sep 11, 2015 08:04 PM
zcherub
Sep 10, 2015 12:03 PM
Kicknshift
Sep 3, 2015 09:35 AM
FRUG35
Aug 31, 2015 02:33 PM
.cakestar
Aug 28, 2015 04:50 AM
