03 metra kid wire harness
I just got the metra turbo kit with wire harnesses. Do they plug in with the stock wires so i don't need to cut into the oem wires?
If so do i need to disconnect the stock amp to avoid any kind of issues?
If you're using a wiring kit instead of the PAC ROEM-NIS2 with a factory bose amp still powering speakers, you're probably going to encounter issues.
This post - https://g35driver.com/forums/audio-v...urce-list.html - exists as the go-to parts and install list for a reason.
Either you disconnected the sensor at the driver's knee area and didn't reconnect it -
https://g35driver.com/forums/audio-v...n-install.html
or your metra trim needs the dip switch set right -
https://g35driver.com/forums/audio-v...ller-read.html
humble_shwoff
Steering & Suspension
Aug 21, 2016 01:14 AM
HipHop615
Accessories
May 20, 2016 12:13 PM
