03 G35 Sedan aftermarket radio issue
Apr 26, 2018 | 06:30 PM
Hey guys, so I’ve got an 03 sedan I swapped out the radio for an aftermarket single din worked great for a long time but started to have issues recently. It would periodically turn itself off then on after a bit, now it’s just gonna completely black (no power). Bought new radio thinking it was issue but no luck!. Went to check the fuse, it was still good but sparked when I put it back into the box under the hood..
if anyone has any suggestions on what the problem could be id appreciate it! Thanks
Reply 0
May 4, 2018 | 09:48 AM
Check and recheck all of your grounds to make sure they are solid. I'd check all of the wiring for the head unit while your at it and re-solder anything that looks suspect.
Reply 0
