DIY guide for installing a sub?
Old Mar 5, 2005 | 05:42 AM
Hyde's Avatar
i dont really wanna pay $150 to get my sub installed
but i cant find much info on how to do it tho. all i know is that i need some 4gauge wire
but i have no idea how the wiring is behind the deck and no idea where the Bose AMP is.
i want to have my sub and bose sub working at the same. where should i hook up my aftermarket sub and amp?
Old Mar 5, 2005 | 02:21 PM
dwoloz's Avatar
Bose amp is in the bottom left part of the trunk well
Youll need a LOC to hook up to the stock wiring; then hook up to your sub amp
Run your power directly from the battery, through the stock grommet through the firewall (SEAL THE HOLE YOU CUT WITH SILICONE), down the passenger side kick panel, under the carpet, through to the trunk and then over to wherever you want it
Old Mar 5, 2005 | 07:49 PM
Hyde's Avatar
is the bose amp at the same place as the coupe for the sedan?
i cant really find it on my sedan
and whats a LOC? can i purchase these at the local car audio shop or bestbuy?
Old Mar 5, 2005 | 08:55 PM
coolice's Avatar
What is an LOC?
I was wondering what a LOC is. It most likely has to do with the fact that you need RCA output from the radio to get the sub working. I assume that you cal also tap into the remote from the bose amp. Does anyone know where to get a wiring harness to prevent from having to tap into the wired?
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Eomfd
Aug 29, 2015 12:42 AM
Gookiecrunch
Aug 19, 2015 12:00 PM
yassy
Aug 9, 2015 07:31 PM
Thunderaan
Jul 22, 2015 07:40 PM
