Bose Amp
Old Feb 20, 2019 | 05:55 PM
Edward27's Avatar
G35 coupe
Bose Amp
what type of amp can be a replacement for the Bose amp that the g35 comes with? Is it a 4 channel or 5?
Old Feb 20, 2019 | 08:10 PM
Scorpi0's Avatar
Any aftermarket 4 channel amp will work. Its gonna take a bit of work to make it happen tho.
See this thread: https://g35driver.com/forums/audio-v...-bose-amp.html
There are also numerous threads about this topic in the audio section of the forum. Our member Wrathernaut knows his śhit about the audio on this car.
Old Mar 22, 2019 | 12:47 PM
Mike Holmen's Avatar
To bad someone doesn't make a Bose amp connectors so you can reuse the factory wiring. I'm installing a replacement two Rockford amps, one for the doors/rear and one going to drive two 10in subs. I wonder how long the factory speakers will last once you put some power to them.
Old Mar 24, 2019 | 06:44 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
You need one that take a differential-balanced signal, otherwise you may end up with about half the power and a lot more noise than usual. JL Amps take the differential-balanced signal, other brands are an amp-by-amp thing, so you'll have to do some research to find out if they can or can't take the signal.
Coupe should be 6 channel, sedan, 5 or 6, with the 6 channel having two bridged to power the sub.
ImportPartsPro
Suspension-Vendor
96
Sep 2, 2015 12:31 PM
Blackout_G35
Audio/Video/Electronics
11
Sep 10, 2012 03:30 AM
sisirknwodtlem
Apr 3, 2011 10:56 AM
