Replacing Bad OEM Radio with another OEM Radio
Old Oct 9, 2019 | 02:56 PM
Supraguy31's Avatar
Veteran: Army
Coupe, Stock
I know this is going to sound strange but I have to ask because I cant figure this out and Im new to these cars.
When I bought my 05 the radio would power on but no sound and then all of a sudden it would make a loud spark like sound and it would work until u turn the car off and the nothing again. Well since then I have purchased 2 OEM radios, (1 from a Supplier and another from a guy that said he just pulled his out) So after taking everything apart and installing the new radio (All 5 wires connected and Antenna plugged in) I turn the Ignition on and I have no power to the radio or any of the AC Components. This has been the case with both radios, I take the original one and put it back in and it powers up fine but ofcourse no sound and the AC controls start working again.
Am I doing something wrong here, Is there something that needs to be done to get a factory radio to work when its replaced with another factory radio. Any help would be greatly appreciated,
Robert
Old Oct 9, 2019 | 05:25 PM
Polishthrust's Avatar
Are you swapping for the same kind of radio, i.e. Bose for Bose or Non-Bose for non-Bose?
Check the ribbon connecting the AC controls to the radio, if it is damaged or the plug its going into is damaged that will cause issues with the radio not powering properly (happened to me).
Old Oct 10, 2019 | 12:54 AM
Supraguy31's Avatar
Veteran: Army
Coupe, Stock
I will check that in the morning, I am swapping Bose for Bose. The one that I got both came out of 04 Models with Cassette Player and 6 disc CD Changer.
Old Oct 10, 2019 | 11:34 AM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Your original problem sounds like it's the Bose amp in the trunk, a well known issue around here.
Old Oct 10, 2019 | 12:07 PM
Supraguy31's Avatar
Veteran: Army
Coupe, Stock
there is an amp in the trunk, If its bad can I just replace it with a Different amp or does it have to be a specific type. I really got to do better reading on these cars.
Old Oct 11, 2019 | 09:28 PM
srv2nv's Avatar
G35 Sport
I believe you would have to replace it with the same amp or else you would have to find an aftermarket amp putting out 2 ohms and run all new wiring and install an aftermarket head unit.
Old Oct 12, 2019 | 12:12 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If it is the amp at least that component is pretty cheap, I think I paid $50 for mine on eBay a year ago and there were a LOT of them for sale.
newyorkg35
Sep 21, 2010 07:36 PM
KwickG35
DFW G35 Owners Club
12
Aug 26, 2009 04:15 PM
azt108
Apr 28, 2009 09:00 PM
andy2812
Jan 27, 2007 10:55 PM
number6
Feb 20, 2004 11:42 AM
