Turn signals cause cruise control to turn off and car to big down
Old Feb 2, 2022 | 02:54 PM
Carsonz's Avatar
Manual coupe
I’ve noticed that when I turn on cruise control, when I tuse the turn signals cruise will turn itself off. To make things even weirder, I’ve also noticed that if I’m accelerating quickly and use the turn signal the car will start jolting with the flashing of the turn signal. When the turn signal light is on the car is noticeably bogged down.
I don’t even know where to begin to look for something like this so any ideas help.
Old Feb 4, 2022 | 09:15 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like the turn signal is slightly shorted out to ground causing a ground issue for other electronic systems.
Since you are also having cruise malfunction I would suspect your steering wheel spiral spring / clock spring is internally failing.
The-Dream
May 28, 2009 09:55 AM
Corrosive
Lighting
Dec 4, 2008 11:14 AM
jokerzcard6
Oct 1, 2006 12:37 AM
topgun
Mar 25, 2005 01:54 AM
