Turn Signal Problem
Old Mar 24, 2005 | 02:18 PM
topgun's Avatar
Turn Signal Problem
I have a 2003 sedan and I have noticed that when I use the turn signal (left or right) that many times it fails to shut off after the completion of the turn. Many fo these turns are 90 degrees or more and some are somewhat less. I have to manually turn it off many times.
Has anyone else had this problem and if so how did you remedy it?
Thanks in advance for any help.
Old Mar 25, 2005 | 01:54 AM
G35Mechanic's Avatar
There is somthing called the steering cam. Its what clicks as you turn if the turn signal is on. Then as your turn the wheel back the first notch it hits it turns the signal off. Its more that likely broken off, but will be covered if your still in your warranty.
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
MsFitFern
Aug 9, 2015 02:58 PM
MT6002
Lighting
Jul 21, 2015 01:13 PM
attarday
Jul 15, 2015 04:03 PM
