Remove spare tire, put Amps there?
Old Apr 2, 2005 | 08:37 PM
caelric's Avatar
Since i will be putting in a JL Audio 500/1, a 300/4, a cap, the JL Audio clean sweep (when it comes out) and my Phatbox, I have more or less decided to remove the spare tire and pu all the amps and stuff there.
Anyone see any problems with this, other than the obvious of not having a spare tire? I have roadside assistance through USAA, and will have a can of fix a flat with me at all times. Will the amps get enough air to not get too hot?
Any other ideas?
Thanks
Dave
Old Apr 2, 2005 | 09:22 PM
dave's Avatar
Be careful if you actually use the Fix-a-flat. Apparently it will mess up the tire pressure sensors. And those things are expensive.
Old Apr 2, 2005 | 11:42 PM
rrpnow's Avatar
or u can just mount the tire under ur car... ask ur dealership, i think they can do it for u.. as in install the under car mounts...
Old Apr 3, 2005 | 09:47 AM
amg35's Avatar
Florida G35 Club
Cooling will be your biggest challenge. If stealth is the reason for using the spare well, consider mounting the amps to the back seat and building a facade to conceal the amps. This will give you a spare, conceal your amps, and allow for better cooling. Take care.
Old Apr 4, 2005 | 10:01 AM
GedOut's Avatar
I’ll be doing same think 2 amps + carpenter ,, I’ll monitor the temperature and install exhaust 120mm fan if needed
Old Apr 4, 2005 | 06:06 PM
amg35's Avatar
Florida G35 Club
monitor the temperature at the amps' heatsink.
Old Apr 4, 2005 | 07:37 PM
Rudy's Avatar
Sound Advice
A have done a few G's with a Memphis 5 channel under the plastic piece to the left of the spare. It fits well, is hidden and has no heat problems. The amp is the mini belle hybid amp 55 watts x 4 ab class and a mono 400 watt d class. Nice amp runs about $600 and has a 3 year warranty.
http://www.memphiscaraudio.com/produ...ails.asp?id=28
Fireman07603
Aug 9, 2015 06:00 PM
wuppiedog
Aug 7, 2015 11:16 AM
Frostbite91
Aug 2, 2015 04:59 PM
justgotg35
Jul 19, 2015 12:33 PM
Jadenkid22
Jul 14, 2015 12:33 AM
