Anyone recommend good 2 amp install kit?
Old May 1, 2005 | 01:49 PM
imRACERX's Avatar
im hooking an Hifonics class D Brutus 1500 at 1 ohm and an alpine 240 i believe for the rest. wondering if you guys could lead me to the right place. i have been told to go with a 2 gauge on the Brutus but not sure the gauge on the alpine. anyway. please help. RX
Old May 1, 2005 | 05:03 PM
tomheo's Avatar
Hi imRACERX,
I've heard good things about www.knukonceptz.com for wiring.
Hope this helps,
Thomas
Old May 1, 2005 | 05:20 PM
imRACERX's Avatar
thanks but they dont have 2 gauge kits. i'm looking to probably just go to best buy or circuit city or even Kmart as long as i get the right kit that holds 2 amps. ive been reccomended 2 gauge for the Brutus amp and 8 or 10 gauge for the Alpine. anyone else? thanks RX
Old May 2, 2005 | 12:40 PM
Zero2sixty's Avatar
JL Audio makes a 2gauge install kit, includes the distribution block and fuse holder for the battery connection. However like mentioned above I'd look into Knukonceptz, look for the 0/1gauge cabling thats the same thickness as the 4gauge (just wider)- I believe its Kompressed Cable. I only mention this because running 0/1 will keep you from having to run new power cable in the future just incase you decide to add additional amps.
Hope this helps
Old May 2, 2005 | 12:53 PM
Zero2sixty's Avatar
Here you go:
JL Audio XA-PCS2-2
2 AWG 12-Volt Power Connection System for 2 Amps up to 1400W RMS / 3000W Peak
20 ft 2 AWG power wire (red)
10 ft 4 AWG power wire (red)
10 ft 4 AWG power wire (black)
Master Fuse Block with 25 Wire Entry / Exit Options and 200 Amp ANL Fuse
Two-way Power Distribution Block with Clear Polycarbonate Cover
Bolt-On Master Ground Lug for Secure Ground Connection
Firewall Grommet for 2 AWG Wire
Black Wire Preterminated with two 5/16" Ring Terminals
20 ft 16 AWG Blue Remote Turn-On Wire
Old May 3, 2005 | 10:52 PM
imRACERX's Avatar
so this 0/1 gauge kit allows for two amps? i need a two amp kit in which one amp needs the 2 gauge and one needs the 8 gauge. please help and provide link. thanks RX
Old May 4, 2005 | 12:53 PM
Zero2sixty's Avatar
Guess I should have asked this 1st, will you be running the HiFonics in a 1 ohm load ?
If you are then ignore the JL amp install kit, you'll be pulling more current....
Assuming you are running the HiFonics @ 1 ohm you definitely need to run a 0/1g (main power feed) from the battery to the trunk, mount the distribution block [ (1) 0/1g input from batt into (2) 4g output to amps ] in close proximity to your amps so you can feed them with 4g power cable. The Brutus accepts a maximum of 4g so your power and ground will be 4g.
Old May 4, 2005 | 07:40 PM
imRACERX's Avatar
thanks for the amp question reply but...
im confused, the Brutus accepts a 4 gauge max and i need the 1 gauge for it if im running it at 1 ohm? im actually running the amp at 2 ohms and getting 1000W to push my puch in series because i cant get them down to 1 ohm because the are dual voice coil and each are 4ohm. anyway how do i feed the amp a 1 or 2 gauge wire if it only accepts a 4gauge wire max? also the quote: mount the distribution block [ (1) 0/1g input from batt into (2) 4g output to amps ] in close proximity to your amps so you can feed them with 4g power cabledoestm make sense to me. can you reword it in simpler terms? i just dont know what you mean. Again im looking to hook up the Brutus at 2 ohms and the Alpine (which is the same as yours) please reply and let me know which kit i should buy. thanks again for your help on this. This is what this forum is all about. How did people survive before the web? RX
Old May 5, 2005 | 12:02 AM
Zero2sixty's Avatar
imRacerX:
Q. "anyway how do i feed the amp a 1 or 2 gauge wire if it only accepts a 4gauge wire max?"
A. A single 2awg cable would run from the battery to the trunk area as close to your (2) amplifiers as possible. The 2awg cable must now terminate into a distribution block (http://www.jlaudio.com/ECS/pdb.html#) because you want to "distribute" the power. At this point you want to run (2) 4 awg cables from the distribution output to the 4 awg inputs on your amplifiers.
Here is a quote from an AMP installation manual which should say pretty much what I said above :
"If you are installing the "AMP NAME" with other amplifiers and wish to use a single main power wire, use 2 AWG or 1/0 AWG main power wire
(depending on the overall current demands of all the amplifiers in the system).This 2 AWG or 1/0 AWG power wire should terminate into a
distribution block mounted as close to the amplifiers as possible and should connect to the "AMP NAME" with 8 - 4 AWGpower wire. Please note that smaller AWG numbers mean bigger wire and vice-versa (1/0 AWG is biggest, 2 AWG is smaller, then 4 AWG, then 8 AWG, etc.)."
Q. "please reply and let me know which kit i should buy"
A. Since it appears that you wont be exceeding 1400rms total for both amps, the JL XA-PCS2-2 is the perfect amp kit for your installation, PM me and I'll tell you where you to get it for the best price - I just ordered mine the other day for my 3 JL amps.
Hope this helped....
Old May 5, 2005 | 12:49 AM
imRACERX's Avatar
hey thanks and PM sent.
also
1.when hooking up my digital capacitor, i connect it between the battery and the distribution block right?
2. Does the distribution block come with the amp kit you speak about?
3. does the distribution block supply the fuses or are the fuse holders separate?
4. does the kit come with both the 2 gauge battery cable and then enough 4 gauge cable for the 2 amps?
5. Thanks again! RX
Old May 5, 2005 | 12:59 AM
imRACERX's Avatar
hey again, i found this kit that supplies an 1/0 gauge but it says its for one amp install.
1. what do you think about it
2. will i just need a distribution block that fits a 1/0 gauge and that kit will be fine?
i assume get the bigger gauge at a cheaper price and just add a block to it. because that jl audio kit seems a bit expensive. any check it out here on ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll...771607585&rd=1
Old May 5, 2005 | 01:42 PM
Zero2sixty's Avatar
Replied to your PM...
A. Yes, closest to the Amplifiers
A. Yes
A. Good question, I have two answers to this question.
The Hifonics has built in fuse capability (maxi fuse 60 & 60) so you won't need a "fused" distribution block. A fused distribution block is used either as added protection to your amps or is required if your amps do not have built-in fuses (built-in meaning an external area on the amp to insert fuses if blown).
You ALWAYS install a fuse block (not to be confused with a distribution or fused distribution block) no more than 18 inches from the battery, the amp kit I recommended provides this fuse block as well as a 200amp ANL fuse.
A. Yes
5. Thanks again! RX
A. Your welcome
Old May 5, 2005 | 01:51 PM
G352NV's Avatar
Never enough
I just bought this one. I think it pretty much has it all! I think he is selling one more in his other auctions.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5770199127&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
Old May 5, 2005 | 09:52 PM
imRACERX's Avatar
hey thanks for the PM. thats a good price.
chinee
Jun 10, 2024 07:48 PM
Jusseth
Sep 13, 2020 12:25 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
hdmark
Apr 29, 2019 04:31 PM
Thunderaan
Jul 22, 2015 07:40 PM
