switched power source in coupe trunk?
Old May 9, 2005 | 11:35 PM
rcdash's Avatar
Question switched power source in coupe trunk?
Hello Fellas,
I have been using the remote lead going into the Bose AMP, but is there a switched power source that can drive an amp or two of 12v (maybe 30W max for some cooling fans)? Or is the remote lead good enough for that much current? Anyone know for sure?
Don't want to have to setup a relay if it's overkill...
Thanks in advance...
Old May 9, 2005 | 11:38 PM
allforthecash's Avatar
Off topic....what color is that wire you are using for the remote turn on?? ..i need to locate a remote turn on as well....
Old May 10, 2005 | 01:02 AM
lexicon's Avatar
check out this post
wire help
I just installed my amp and sub a couple days ago
Old May 10, 2005 | 11:30 AM
rcdash's Avatar
Remote Wire Light Blue/ Silver
any advice on the power draw that is acceptable from that line???
Old May 11, 2005 | 10:00 PM
KPierson's Avatar
Typically a remote turn on lead should be assumed to be 100ma. Just enough to run a relay. I wouldn't try running fans off of any remote turn on lead personally... Go with the relay and be sure you are doing it right and not risking damage to your hu.
Old May 12, 2005 | 04:27 AM
dwoloz's Avatar
Listen to KP, switched power lines are not meant for powering high draw components
Use a relay that will trigger use of constant power
Relays are only a few bucks and take mere seconds to wire; just do it
Old May 12, 2005 | 09:53 PM
rcdash's Avatar
thanks fellas. will drop by radio shack to pick up a relay.
Frostbite91
Jul 27, 2015 05:25 AM
Kal Hamm
Jul 24, 2015 08:55 AM
MT6002
Lighting
Jul 21, 2015 01:13 PM
G35_EAZY
Jul 19, 2015 01:38 PM
