eclipse AVN 5435 install question
Old May 10, 2005 | 12:18 AM
6mt/brembo's Avatar
I just bought a AVN 5435 and going to have it professionally installed on wednesday my question is I heard you can override the system to play dvd's while driving with this unit I know on the older unit you ground out the parking brake wire is this unit the same way I want to tell the installer incase he doesn't know also is there any other things I need for the installation I bought the pac-swi-x for the steering wheel controls but do I need wiring harness antenna adapter ect ?? any information on the install of this particular model would be great Ill take pics when it's done
Old May 10, 2005 | 12:42 AM
GRider35c's Avatar
yes you will need antenna adapter.
i dont think they make a wiring harness so your installer will need to do it him/herself.
ok for the new 5435 even if you ground the parking brake wire, over 20mph it will still turn off the screen during dvd viewing, to bypass this, hook up a switch on your speed sensor wire so that when youre watching dvd's you unswitch it so theres no feed from your speed sensor wire to the head unit, then when you do navi, switch it back on!
as far as i know, this has never been tried yet, but we're sure it will work!!!
good luck, you will love it!!! i have the older 2454 model... same ish tho!
Attached Thumbnails eclipse AVN 5435 install question-dsc01689.jpg   eclipse AVN 5435 install question-dsc01683.jpg   eclipse AVN 5435 install question-dsc01685.jpg
Old May 10, 2005 | 12:43 AM
GRider35c's Avatar
also, this is where i put my pac swi-x "eye"
Old May 10, 2005 | 12:54 AM
6mt/brembo's Avatar
thanks for the quick reply do i get the antenna adapter from infiniti or should the stereo shop already have one
Old May 10, 2005 | 01:17 AM
GRider35c's Avatar
stereo shop!
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Nicksims13
Oct 15, 2015 01:57 AM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
