Power outlet in car?
Old Jun 20, 2005 | 03:09 AM
cloud's Avatar
Is it possible to err install a power outlet(regular?) in the car which draws power from the battery, and a Video/Audio input(like those u have in ur TV) which is linked to the indash dvd player?
What are the correct terms for them(I'm not an audiophile)? and where would be the best place to mount one(concealed maybe)?
edit: I intend to power stuff from laptops to PS2s , will that be a problem?
Old Jun 20, 2005 | 03:19 AM
codeflux's Avatar
you need a 12V to 110V inverter. get yours in an auto department of your local walmart or home depot.
Old Jun 20, 2005 | 03:40 AM
mcastlejr's Avatar
power outlets
Speaking of which, do the 05's only have one power outlet, under the armrest? I guess that I am used to SUV's which have like 3 or 4. The cigarrette lighter cannot be used as one can it?
Thanks.
Old Jun 20, 2005 | 03:53 AM
codeflux's Avatar
not sure about 2005 models, but my 2003.5 has 3 outlets - one in the arm-rest, and two more on each side of the center console (one at driver's right knee, one at passenger's left knee).
Old Jun 20, 2005 | 11:50 AM
god_of_cpu's Avatar
StreetDeck.com Developer
Thanks.
Either the cigarette lighter or the regular power outlets will work, however, it is recommended that you only use the specifically marked power outlets for powering anything and don't exceed the wattage recommendations on them.
The only real difference, I believe, between the outlets is the length and gauge wire the outlets use, with the power outlets using a slightly lower guage to allow for more power, safely. I wouldn't recommend hooking up an inverter to the cigarette lighter port or anything that draws alot of power if you can avoid it, but more then likely the only bad thing that will happen if you do exceed the capabilities of the port is you will blow a fuse.
Old Jun 21, 2005 | 01:43 AM
dwoloz's Avatar
Thanks.
I dont have an 05 but I believe theres one in the armrest then one in the ashtray
Old Jun 21, 2005 | 04:07 PM
cloud's Avatar
hmm what about the Video/Audio(Yellow Red White) input if I don't wanna hardwire the ps2 or something to the car(plug anything in)? Can I install an outlet for those somewhere in the car?
Old Jun 21, 2005 | 05:19 PM
G35_coupe_6MT's Avatar
05's have two power outlets. One inside arm rest and the other is the lighter thing that is located in the trash compartment below the stereo.
Radioshack has 12v to 110v converter. Make sure your car is ON while you use 110V or your battery will drain FAST.
Old Jun 22, 2005 | 01:15 PM
rcdash's Avatar
DC to AC converters are very inefficient - so yes, keeping the car running is important. Most equipment (laptop, PS2) just converts this back to DC. It is MUCH more efficient to get a DC/DC power suppy (converts batteries 10-14V to a clean steady 12V) - check out www.logicsupply.com and www.mp3car.com - (I use the OPUS 150W to power my car PC and some ancillary low power equipment).
If you need another voltage, you may be able to find the appropriate DC/DC converter online.
Old Jun 22, 2005 | 01:24 PM
O NO's Avatar
Staff ALUMNI
I've got an inverter that I hook up to either the port in the arm rest or the one on the passenger side. I use it for my video camera, bullet cam and aux. mike when taking vids while rolling. Haven't had any problems with it. If you go this route I would suggest to get a good quality inverter.
As it was stated here before, only use those two ports, not the cig lighter port. This was told to me also by the service manager at our local infiniti dealer.
Old Jun 23, 2005 | 05:57 PM
MAZyar's Avatar
I'm using the passenger side outlet to power my xbox via an inverter, no issues, no noise, no heat, all working fine.
Old Jan 22, 2006 | 03:10 PM
rraabb11's Avatar
adding an outlet
anyone every add a cig outlet to there 05? one just isnt enough- (other that in the tray)-possible add a mirror image to the other side of the armrest (inside)? sounds sweet doesnt it?
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
BlackGee35
Jul 21, 2015 07:24 PM
beevanhuynh
Jul 14, 2015 09:06 AM
