Tweeter removal (05 sedan Bose)
Old Jul 9, 2005 | 09:31 PM
danl's Avatar
I swear that about 6 months ago I saw someone post about removing the stock tweeters through the grille instead of taking apart the door. Can anyone confirm this and/or help me track down the post?
Old Jul 9, 2005 | 09:54 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
'04 door has to come apart.
(have mine apart now)
I am not aware of any change to the '05
Old Jul 10, 2005 | 01:50 AM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
I just reviewed the 2005 Service Manual, both the AV and the EI sections and it does not specifically say if you have to take the whole door panel off or just that tweeter grille to get at the tweeter. Sorry.
doc
Old Jul 10, 2005 | 01:57 PM
tomheo's Avatar
I don't think it's possible to do it without removing the door panels since the tweeter grill extends down into the door panel area a few inches. It's actually pretty easy to remove the door panels, but the driver side is a little tougher due to the wires for the power lock/window control console thing.
Hope this helps!
Thomas
Old Jul 11, 2005 | 03:40 AM
FrizzleFry's Avatar
the door panel you could just hang it off if you're not changing the woofer. then there's just 2 pop clips for the tweeter trim piece. it's one solid piece as mentioned... no way to remove the tweeter w/out removing the panel.
Old Jul 11, 2005 | 09:12 PM
danl's Avatar
Thanks, here's hoping I don't have to take it apart too many times.
Old Jul 11, 2005 | 09:44 PM
FrizzleFry's Avatar
a panel popper and a cloth under a small screwdriver are your friend. to the get aluminum trim off you'll need taht small screwdriver and cloth so you don't scratch/dent anything. The panel popper I use with a cloth as well so as not to scratch. And be careful putting it back on... make sure the panel clips are aligned correctly before pushing.
Xanthan Gum
Aug 6, 2015 10:49 AM
Frostbite91
Aug 2, 2015 04:59 PM
kd03g99
Jul 30, 2015 11:24 AM
Thunderaan
Jul 22, 2015 07:40 PM
