Can someone give me a hint on removing 2005 Clock area?
Old Jul 10, 2005 | 01:58 AM
G35_TX's Avatar
I need to remove the clock area to fix a rattle/ticking that started. Can anyone tell me how to get that darn thing out? I tried pulling straight up but it wouldn't budge.
Old Jul 10, 2005 | 02:16 AM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
PULL HARDER woman!!!! j/k
Straight from the 2005 Service Manual:
Picture #1. Pull to the backside, disconnect clips and pawls and remove cluster lid finisher upper
Picture #2. Disconnect pawls and clips, and remove cluster lid finisher lower
Attached Thumbnails Can someone give me a hint on removing 2005 Clock area?-mvc-015s.jpg   Can someone give me a hint on removing 2005 Clock area?-mvc-014s.jpg
Old Jul 10, 2005 | 02:18 AM
G35_TX's Avatar
Pull to the backside? What the heck does that mean?! Uggg
Old Jul 10, 2005 | 02:22 AM
docron1's Avatar
I think it means to pull towards the BACK of the car.....
to remove this piece in the 03-04's, you had to pull *really* hard towards the REAR of the car.
doc
Old Jul 10, 2005 | 11:51 AM
g35driver05's Avatar
^^^ What he said... you really have to yank on it.. the first time. There are 2 tabs that are fixed in place and they will break off when u remove it the first time. After the first time its a breeze .. there are just 2 plastic clips holding it in place..
But yea. you have to pull it towards the rear of the car.. ( towards the back seats)
Hope that helps
Old Jul 10, 2005 | 12:32 PM
BlackonBlackG35's Avatar
You have to show that stupid piece of plastic WHOSE BOSS!!!
Old Jul 31, 2005 | 06:20 PM
bsoo's Avatar
confused
OK I'm really confused. Attached is an excerpt from my 2003 service manual (page IP-14) and it says to pull it UPWARDS. So which is it? If it's really backwards, how am I supposed to pull it backwards, as there is nothing to grap onto in that direction?
Anyone has pictures of the back side of this "cluster lid finisher"? If I can see it then perhaps I can visualize it.
Thanks.
Attached Thumbnails Can someone give me a hint on removing 2005 Clock area?-cluster-lid-finisher.gif
Old Jul 31, 2005 | 09:23 PM
Gee Im Fast's Avatar
Thanks.
03/04 is different from 05. The top portion is pulled out (towards you). Once that is done, the bottome protion is to be lifted straight up. 2 Piece assembly for 05.
Old Aug 2, 2005 | 12:15 AM
GoSooners's Avatar
I got rattles up there too. Let us know how you took care of it.
Old Aug 2, 2005 | 08:14 AM
G35_TX's Avatar
Just like the post above on how to remove it. I just put some padding behind the clock assembly. Be careful not to loose the snaps!
tiguy99
Mar 1, 2016 11:42 AM
miata007
Aug 17, 2015 04:36 PM
wuppiedog
Aug 7, 2015 11:16 AM
socalg35x
Jul 28, 2015 10:42 AM
Blakelyg35
Jul 21, 2015 12:49 PM
