Valentine Hard Wire to Homelink
Old Dec 9, 2005 | 10:19 AM
  #31
DRAGMODE's Avatar
Originally Posted by tomcatm
Appreciate your offer, but its all good, I dont think its worth the trouble for a small amount of money. My delivery date is the 14th so ill post the results soon.
what length cord did you order? 6" or 8"? I want the shortest cord possible...wondering if 6" is long enough?
i'll be using mikes mount w/ a V1
Old Dec 9, 2005 | 12:06 PM
  #32
TeamSpeed's Avatar
If you have wire or twine around, cut about a 6.5" and an 8.5" section, and then try to measuring which fits best. If your detector is going to be mounted such that the phone jack is really close to the harness (right under the mirror, suction mount next to the mirror), 6" should be enough.
Old Jan 15, 2007 | 04:11 PM
  #33
n1cK's Avatar
G35 6MT
Originally Posted by Gee Im Fast
3) From the end that you cut the phone jack off on your V1 wire,the ends of the Green Wire (this is your ground) and the ends of the red wire (this is your +12V) are all you will connect to the homelink. The yellow and black will not be used.
exactly what i needed!!
Old Jan 20, 2007 | 08:46 PM
  #34
n1cK's Avatar
G35 6MT
by the way, what are the yellow and black wires used for? i'm trying to install a bypass switch for my concealed display.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
BfloG35
Oct 16, 2015 05:22 PM
9tray turbo
Sep 29, 2015 10:22 PM
the93owner
Sep 28, 2015 10:37 PM
