Can I just replace the OEM amp to afterMarket amp?
Originally Posted by m500
Can I just replace the OEM amp to afterMarket 4/ch amp? Will there be significant improvement over stock BOSE amp?
Getting even a relatively (under $200) set of components (Kenwood comes to mind) makes a huge difference in sound. More so than if you change the AMP. I would recommend changing front speakers first, then go from there. 4 ohm speakers will work fine (but will be a little quieter at the same volumes than Bose so may have to fade to the front to balance).
With the current Bose systems, you'll want new speakers and an amp. Then consider getting an aftermarket HU. If you have the money, do it all at once so you won't have to take apart your car multiple times. I'm still working on my car and it's been almost a month. You can really hear all the rattles when you drive around in a stripped car but I'm still waiting on my parts to arrive.
mjfenix
Aug 17, 2017 05:49 AM
bTanz
Oct 15, 2015 02:31 PM
Thunderaan
Jul 22, 2015 07:40 PM
