DIY Door Panel Removal
Old Jul 31, 2005 | 05:56 PM
Gmachine's Avatar
When I took my G Coupe doors apart I could not find a picture DIY to do so. It is actually pretty easy to do for all of you out there looking to change your front speakers. First thing you want to do is roll down your windows, it is much easier to get the panels off with the window down (If you disconnect the battery to work on any electronics it is crucial because you could crack the windows if you try to close the door.)
Tools you will need: A long flat tip screw driver and a 10 mm socket with extension.
First Step, locate and remove the small clip that covers the first screw.
Second, pry off the silver plastic trim that covers the handle by inserting the flat head screw driver into the notch at the bottom of the trim piece. Pull the screw driver toward your self to pop the trim piece off (It is on pretty securely so it might be a little tough). Remove the two screws with the socket wrench.
These are all the screws and pieces that you should have out:
Next, pry out the four plastic clips from the bottom of the door. It is simple to find these because of the cutouts at the bottom of the panel.
Pull on the panel from the sides starting at the bottom and work your way to the top. The door panel will not fall because it hinges in the window opening at the top of the door. You can pull up on the panel to get it out of the window opening only a few inches because it is attached with the door handle/lock cables, and two wiring connections. Hold the panel up with your elbows as you disconnect the connections if you don't have someone to help you.
Use the flat head screwdriver to disengage the wiring harnesses. Pull the lock and door panel cables up to remove them from the panel. You can now take off the panel.
Old Jul 31, 2005 | 05:57 PM
Gmachine's Avatar
Finally
This is what the door looks like with the panel off (Sorry it's the left door with my new speaker installed, also the window is up because I had just drilled into the door to mount my spacers). The stock bose speaker comes out easily with 3 screws and one wire connection.
Old Aug 2, 2005 | 10:19 AM
Gilley's Avatar
Nice writeup and pics. Good woodworking skills.
Old Aug 2, 2005 | 10:56 AM
Espresso's Avatar
It's hard to believe but the G35 is one of the easier cars I have taken apart to install stuff. Nice install.
Old Aug 2, 2005 | 01:17 PM
speedgeek's Avatar
Thumbs up
Great Writeup & Pics!!! I'll be doing this at some point w/ my G
Thanks!
Old Aug 2, 2005 | 01:57 PM
Gilley's Avatar
I'm going to follow these instructions to add some foam between the door and the door panel to try to eliminate some rattles.
Old Aug 2, 2005 | 02:01 PM
madchef's Avatar
Great writeup! Can we move this to the DIY section?
Old Aug 2, 2005 | 10:17 PM
Gmachine's Avatar
When you try to get rid of the rattles, a little weather stripping between the door plastic around the mounts for the clips does the trick. I had a rattle at the top of the drivers door close to my head and the weather stripping took care of it. Also, the plastic clips have a thin felt washer that goes on the clip between the plastic and metal but only on the clips at the bottom of the door.
Old Aug 4, 2005 | 11:48 AM
digitalhifinet's Avatar
nice utopias
Old Aug 4, 2005 | 12:38 PM
BlackonBlackG35's Avatar
much appreciated...
Old Aug 6, 2005 | 11:53 AM
Gmachine's Avatar
I was able to mount my amp and utopia crossovers on the back of the rear seat. Worked out really well.
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
Mick_L
Aug 25, 2015 04:27 PM
ev_g35
Interior
Aug 14, 2015 02:05 PM
will091195
Jul 27, 2015 09:19 PM
