Bose Grill, sedan rear deck
Old Aug 1, 2005 | 05:02 PM
mark5's Avatar
I have a 03 sedan, how can I get to the bose grill, the one on the rear deck for the sedan? I need to tighten it. The rattles are driving me nuts
Old Aug 2, 2005 | 11:30 AM
mark5's Avatar
bump
Old Aug 2, 2005 | 11:47 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
It is a snap in grill.
The only way to tighten is to remove it & add some padding etc to tighten the clips.
To remove:
There is a clip on each side & two on the front.
The back has longer inserts.
You need to squeeze the sides while prying back, then up on the front.
(grill comes up & forward to remove)
Be carefull not to snap them off!
FWIW,
I'd remove the entire rear parcel shelf & add some dynamat & padding.
It's probably not just the grill causing the noise.
Good luck.
Old Aug 2, 2005 | 03:33 PM
mark5's Avatar
so i don't need any tools, just get to it from the top?
Old Aug 3, 2005 | 01:19 PM
InTgr8r's Avatar
From the top = yes.
Tools = something to pry with (flat screw driver wrapped or taped to prevent damage)
mjfenix
Aug 17, 2017 05:49 AM
yoyoyo8
Aug 12, 2015 03:04 AM
teamghost
Jul 28, 2015 04:52 PM
Thunderaan
Jul 22, 2015 07:40 PM
